Typcasting Variables inside of Arrays
Results 1 to 7 of 7
    Alabama,USA
    Default Typcasting Variables inside of Arrays
    Why is it that if I define variables by typcasting Variables inside of Arrays I can not use HighByte and LowByte on those variables? When I do, I get an error message that says "attempt to redefine (the variable)"?
    Miami, Florida USA
    Default Re: Typcasting Variables inside of Arrays
    This thread might help you
    http://www.picbasic.co.uk/forum/show...ghlight=arrays
    Anonymous
    Alabama,USA
    And there we have it!
    Thanks Robert, It looks like I will be adding one more variable to the program.
    For more versatility, you might consider this ...
    The EXT (external) modifier.
    http://www.picbasic.co.uk/forum/show...php?t=3891#TYP
    Alabama,USA
    Darrel, EXT can't be that versatile. I'm using the EXT modifier, its your code example I'm using.
    Serout2 TX_USB, 84,[" DSvolts is ",bin DSvolts.highbyte,bin DSvolts.lowbyte,13,10]
    this won't compile. Should it? Or could I have a Bank problem?
        DSbuffer  VAR BYTE[9] BANK0
    ASM          ;Typcasting Variables inside of Arrays
    DSstat    = _DSbuffer      ; byte
    DStemp    = _DSbuffer + 1  ; word
    DSvolts   = _DSbuffer + 3  ; word
    DScurrent = _DSbuffer + 5  ; word
    DSthres   = _DSbuffer + 7  ; byte
    DScrc     = _DSbuffer + 8  ; byte
        DSstat      VAR  BYTE  EXT ; Status/Configuration
        DStemp      VAR  WORD  EXT ; Temperature
        DSvolts     VAR  WORD  EXT ; Voltage
        DScurrent   VAR  WORD  EXT ; Current
        DSthres     VAR  BYTE  EXT ; Threshold
        DScrc       VAR  BYTE  EXT ; CRC
    PBP can't use HighByte and Lowbyte because it doesn't know where the variable is when PBP is compiling. The location isn't known until it's Assembled.
    Try it like this, which specifies the High and Low bytes as EXT too.
    DSvoltsL  = _DSbuffer + 3  ; byte
    DSvoltsH  = _DSbuffer + 4  ; byte
        DSvoltsH    VAR  BYTE  EXT
        DSvoltsL    VAR  BYTE  EXT
    Serout2 TX_USB, 84,[" DSvolts is ",bin DSvoltsH,bin DSvoltsL,13,10]
    Alabama,USA
    Amazing!
    Thanks Darrel.
