Please Help How Simplifies my code
Results 1 to 7 of 7
    Oct 2008
    Default Please Help How Simplifies my code
    HI EVERYONE
    CODE IS WORKING BUT.
    I AM CONFUSED THAT CODE TAKE LONG SPACE FOR SIMPLIFI WHAT IS AN OTHER WAY?
    MY CODE IS
    @ DEVICE PIC16F688, HS_OSC, WDT_OFF, PWRT_OFF, MCLR_OFF, BOD_OFF,PROTECT_OFF
    DEFINE HSER_SPBRG 9 ' 115200 Baud @ 18.432MHz, 0.0%
    TRISA =%11111111
    TRISC =%11110111
    ANSEL = 0 'ALL DIGITAL
    INTCON = 0 'Disable interrupts
    DATAIN VAR byte[7]
    X VAR BYTE
    LED VAR PORTC.3
    MAIN:
    HSERIN [WAIT($07,$06), str DATAIN\7]
    GOSUB A
    GOSUB B
    GOSUB C
    GOSUB CK
    GOTO MAIN
    A:
    IF DATAIN[2]=$2D AND DATAIN[3]=$A1 AND DATAIN[4]=$00 AND DATAIN[5]=$CD AND DATAIN[6]=$C2 THEN
    X[0]=1
    X[0]=0
    B:
    IF DATAIN[2]=$2B AND DATAIN[3]=$FA AND DATAIN[4]=$3B AND DATAIN[5]=$65 AND DATAIN[6]=$0C THEN
    X[1]=1
    X[1]=0
    C:
    IF DATAIN[2]=$2E AND DATAIN[3]=$69 AND DATAIN[4]=$06 AND DATAIN[5]=$A6 AND DATAIN[6]=$21 THEN
    X[2]=1
    X[2]=0
    CK:
    IF X[0]=0 AND X[1]=0 AND X[2]=0 THEN
    LOW LED
    HIGH LED
    GOTO MAIN
    Default Re: Please Help How Simplifies my code
    Try splitting up the long logical expressions, like:
    A:
    IF DATAIN[2]=$2D THEN
      IF DATAIN[3]=$A1 THEN
        IF DATAIN[4]=$00 THEN
          IF DATAIN[5]=$CD THEN
            IF DATAIN[6]=$C2 THEN
              X[0]=1
     X[0]=0
    Oct 2008
    MANY THANKS MY BROTHER HenrikOlsson FOR REPLY
    WHAT YOU THINK ABOUT
    SELECT CASE
    HOW CAN I USE ?
    You're welcome, but there's no need to SHOUT all the time ;-)
    SELECT CASE might give you "neater" code but I've found it usually produces larger code than IF-THEN constructs and in this particular case I don't think Select Case is of any use to you.
    Another thing that might be worth a try is to do the extract the values from the array into temporary variables first, then run your comparisons. Something like:
    TempA = DataIn[2]
    TempB = DataIn[3]
    TempC = DataIn[4]
    TempD = DataIn[5]
    TempC = DataIn[6]
    GOSUB A
    GOSUB B
    'And so on
    A:
      If TempA = xx THEN
        If TempB = xx THEN
    'and so on
    I'm sure there are more you can do depending on exactly what it is you're trying to achieve.
    Aug 2010
    Maryland, USA
    Are you sure this is not the reason for the slow code?
    After all, no matter how you code the checks, the pic will not take a noticable time to process that. If it compiled to 1000 lines of code, @4Mhz clock it would only take 1mSec
    What clock speed?
    -Bert
    Oct 2008
    A:
              X[0]=1
     X[0]=0
    ABOVE CODE IS NOT WORKING
    THIS IS A GOOD FORUM FOR BEGINNAR LIKE ME AND I HOPE HELP SO,
    MY PROBLEM IS NOT slow code CLOCK IS 18.432MHz
    100,S STRING I WANT COMPARE
    Of course it doesn't, sorry about that. Try this instead:
    A:
    X[0]=0
              X[0]=1
    And please stop SHOUTING all the time, it's hard to read!
