You're welcome, but there's no need to SHOUT all the time ;-)
SELECT CASE might give you "neater" code but I've found it usually produces larger code than IF-THEN constructs and in this particular case I don't think Select Case is of any use to you.
Another thing that might be worth a try is to do the extract the values from the array into temporary variables first, then run your comparisons. Something like:
TempA = DataIn[2]
TempB = DataIn[3]
TempC = DataIn[4]
TempD = DataIn[5]
TempC = DataIn[6]
GOSUB A
GOSUB B
'And so on
A:
  If TempA = xx THEN
    If TempB = xx THEN
'and so on
I'm sure there are more you can do depending on exactly what it is you're trying to achieve.
