18F4523 beginner needing help to blink an LED...
Results 1 to 23 of 23
    Feb 2011
    Default Re: 18F4523 beginner needing help to blink an LED...
    Thanks for all the replies.
    I have just checked my microcode studio and it is currently using MPASM, thanks for the pointer though, if this was set wrong I would have never found it...
    I'll have a play with the code posted tomorrow, and post how I get on.
    Cheers,
    AD.
    Feb 2011
    Still cannot get anything to work with this PIC18f4523.
    My code is (at the moment...):
    DEFINE OSC 8
    OSCCON = %01110000
    ADCON0 = %00000000
    ADCON1 = %00001111
    CMCON = %00000111
    TRISE=0
    TRISD=0
    PORTE.0 = 1
    PORTD.2 = 1
    I have tried various different things all day but I still cannot get any output.
    I cannot try the code Brian supplied as it was for a different PIC (well, I did try it but it did not compile with the @__... lines in place, once I'd rem'd them out it programmed fine but still did not work). I can't use a 18F2320 as this has not got enough pins for the final project I want to use this pic for, and ideally I would like at least 1 12 bit adc, preferably 2.
    What exactly happened?
    To set the configs in code space
    Your are using MPASM as the assembler?.
    Quote Originally Posted by thesparky View Post
    DEFINE OSC 8
    OSCCON = %01110000
    ADCON0 = %00000000
    ADCON1 = %00001111
    CMCON = %00000111
    TRISE=0
    TRISD=0
    PORTE.0 = 1
    PORTD.2 = 1
    You also need to set adcon2 on the PIC18F4523. It might be better to try a 10 bit a to d converter first. Maybe a PIC18F452 once you get that working you move to a 12bit converter. PBP adcin command may not work since it is geared to 8 and 10bit adc's.
    Good luck
    Nothing like a quick search. See Bruce's example
    http://www.picbasic.co.uk/forum/show...ighlight=12bit
    Feb 2011
    mackrackit
    The compiler did not seem to like the commas.
    e.g @ __CONFIG _CONFIG1H, _INTIO2_OSC_1H & _IESO_OFF_1H
    I have just tried the line:
    @__CONFIG_INTRC_OSC_NOCLKOUT
    and it seems to compile with this. I do not know what this does and do not know if it applies to this PIC, but I was just seeing if would complie.
    I am using MicroCode Studio, and when I go to View/Compile and Program Options/Compile Tab the use PBPL checkbox is ticked (although I have tried unticked) and when I go to the Assembler Tab the Use MPASM is ticked. I have not changed any of the settings (appart from PBPL) since I have been programming a 16F690 and this seems to program fine.
    mark_s
    I think I may be confusing the issue with the A-D convertor. I do not want any A-D stuff yet, I just want a simple?!? digital output to prove to myself that my setup works. I will look at ADCON2 now though. I tried another PIC18F4523 and this does not give me any output either. I have re-checked all the connections with a DVM and they all seem fine.
    If I still have no luck over the weekend then I will buy some different pics on Monday.
    Feb 2011
    I looked into ALL DIGITAL and thought it would be the answer to all my prayers...
    My Code is now as follows:
    INCLUDE "ALLDIGITAL.pbp"
    define SHOWDIGITAL 1
    TOGGLE PORTE.0
    PAUSE 1000
    GOTO Main
    Unfortunately I still cannot get any outputs.
    When compiled I get the following messages in the results window:
    ADCON1 = 0x0F
    CMCON = 7
    I have rechecked my software and hardware by programming another Pic, a 16F690, and this programs fine.
    I am beginnig to think I may have a dodgy couple of IC's. I'll try and build another board up next Monday to rule out this, although I can program and read the pic with the setup I have now.
    Any other things I can try?
    I do not have this chip but give this a shot
    '18F4523 INTERNAL OSC 8MHZ Internal oscillator block, port function on RA6 and RA7
    @ __CONFIG    _CONFIG1H, _OSC_INTIO67_1H  & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 8
    OSCCON = %01110000
    ADCON1 = %00001111
    CMCON = 7
    TOGGLE PORTE.0
    PAUSE 1000
    GOTO Main
