Low frequency audio level detector using PIC ADC?
Results 1 to 40 of 69
    Mar 2009
    Default Re: Low frequency audio RMS signal level detector using PIC ADC?
    Eeek, even a little bit of code like this....
        toggle PortC.4   'pin 6
        'count1 = count1 +1
        present_sample = ADRESH
        IF  present_sample < 128 then
        present_sample = (127 - present_sample)
        present_sample = present_sample -128
        IF present_sample >= rolling_peak THEN
        rolling_peak = present_sample
        if count1 =  50 and rolling_peak !=0 then
        rolling_peak = rolling_peak -1
        count1 = 0
    is only toggling at 16khz - meaning that the main loop is only running at 30khz ...gulp (that's not leaving much room for anything else) bearing in mind I only have a 20khz sample rate going on...I wish the 16f1828 didn't have the ADC iissue about 8Mhz internal clock, becuase the obvious way of winning back por main loop time is to crank the internal clock up.
    Aug 2010
    Maryland, USA
    Default Re: Low frequency audio level detector using PIC ADC?
    what is your device ID and REV?
    -Bert
    Mar 2009
    I don't know...and it's possible they've fixed the problem for the ones I have (purchased just a couple of weeks ago)
    I use a Pickit2 programmer & can't seem to find anything that tells me such device info?
    In the light of needing more 'main loop time', I've actually just cranked the Oscillator up to 16Mhz...and the ADC aspect still seems to be working ok.
    Aug 2010
    Maryland, USA
    Per the errata, they have fixed it for all current stuff. So unless your supplier has old stock, you are prolly good. I didn't think to look at the date on the errata, that may shed some light on if it will work. It sounded like it will either work or not. It didn't sound like it could be interminent.
    And remember to change your ccpr values to reflect the faster clock. - unless you want to double the samples
    -Bert
    Mar 2009
    Thanks Bert - Actually, I think we're done here would you believe! (Bert sighs in relief!)
    I've aborted any attempt to confirm the sampling rate & have reasonable faith in our calculations! I've got the PIC Internal Oscillator running at 16 Mhz, and a special event trigger frequency of of 16Khz (ADC sample rate ), ie Timer1 matching against this....
    CCPR4H = 0
    CCPR4L = 250
    (16Mhz clock, 4Mhz Instruction = 0.00000025sec period, therefore 250 x 0.00000025 = 0.0000625 sec .....so 1/0.0000625 sec= 16Khz)
    ....I've integrated the 'peak detect' code above into the final destination main loop - I've scoped a pin toggling within my my main loop @50khz which means it's looping at 100khz (so plenty of time to do other stuff in the main loop if I so desire). I don't use any interrupts except for switch presses,...and when a switch is pressed, I'm not worried about losing ADC samples.
    ...just connected it up to my guitar (vs the sig gen I've been testing with)....it's working as expected
    A *very* happy Hank...thanks for all your input.
    Aug 2010
    Maryland, USA
    Quote Originally Posted by HankMcSpank View Post
    No sigh at all Hank, I really enjoy these kinds of threads. Lots of new things learned by all. I don't seem to have the imagination or desire to make such projects, but I LOVE thinking about them.
    So Thank YOU and I look forward to your next one.
    BTW, I agree you should consider making a WIKI of this. Your coding is fine, as Dave said you underestimate yourself. I do get the time aspect of it.
    -Bert
    Thumbs up from me too.
    Good idea with just a few components and clever programming. To the Wiki absolutely!
