Low frequency audio level detector using PIC ADC?
Results 1 to 40 of 69
    Aug 2010
    Maryland, USA
    Default Re: Low frequency audio RMS signal level detector using PIC ADC?
    Ok, after some careful reading of the datasheet, I find I am no longer any smarter then I was before I started. I can't find anywhere in the datasheet to say in compare mode timer is reset on a match. It DOES say for the Special event trigger the timer is reset. So I suggest this:
    Go back to SET mode (Special Event Trigger).
    Enable interrupt on A/D conversion done.
    Have the ISR do this:
    toggle a pin (for debuging speed)
    move A/D results to a variable for later use
    Return from INT
    With that done, several things are solved for you.
    -Bert
    Hank,
    1. why don't you make a full rectifier of your analog signal?
    2. is the signal always of the same amplitude?
    3. are you after a peak detector or an rms calculator? I am little confused by this thread...
    Mar 2009
    Hank,
    Hi Ioannis,
    Ok, I came into this thinking I needed an RMS detector - I don't (despite the title ....which I'm unable to update/edit)....I really want to track 'peak' of a guitar signal. The incoming signal is of very wildly differing amplitude.....but fortunately it only goes up to 1.5khz max (the max fundamental on a guitar...I don't care about the harmonic content here - I'm only wanting to extract magnitude info, not accurately replicate the waveform digitally)
    So why not use conventional analogue components? Well I'm *very* pushed for PCB real estate ...the intended PCB will already have a PIC, but the PIC isn't doing much (basic switching, LED indicators etc) ...so that got me thinking, why not extract peak from the incoming analogue signal using the PIC - just like an analogue full wave rectifier into a peak detector (which is what my code above is doing ....'full wave rectifying a signal' but via code inside the PIC) ...if nothing else, my intention was to learn a little more about sampling an AC signal rapidly .....& like most journeys - you discover other stuff enroute. And that has proved to be the case - the special event trigger - it's been a revelation to me at least.
    Not only do I save components (PCB space)...I also avoid the forward voltage drop loss that an analogue peak detector suffers from (this is a relatively small signal I'm monitoring)...but it struck me I can also have on the fly varying 'discharge' rates to suit as my peak detector is now working in the digital domain.
    The nut has actually been cracked ....all that's happening here now is a bit of a wash up...trying to get to the bottom of a couple of quirks I'm hitting (specifically the calculations wrt sample rate, etc)
    Bert,
    Again...great ideas...I'll implement this later to get a handle on the sampling frequency (I concur that the datasheet is a bit scant with the 'meat' here!)
    The first that comes to mind is to use a DSP or dsPIC for the job as there seems to be a lot of maths.
    But then since the max frequency is just 1,5KHz then maybe the PIC used is good enough.
    Of course it has the speed to convert the input sample, but do you have time to proceess afterwards?
    The other matter is the form of the input signal. You mentioned that it is greatly varying. Are you feeding it directly to the ADC? Any pre-conditioning I thing is necessary (filtering, dc-level bias etc.).
    P.S. I changed the thread title hoping you do not have any objection.
    Mar 2009
    Actually, that's the beauty here - there's almost no complicated maths....ie just et the special event trigger grabbing ADC samples at a reasonably high sampling rate (& this is all done in the background without any recourse to interrupts etc), then in the main (fast) loop, just compare the present ADC sample to the last sample...if it is the same or bigger, keep it as the 'present peak'....if it's not the same or bigger. start decrementing the variable linearly.
    This approach wouldn't be right, if the PIC was already running intensively....but like I say, in my application the PIC isn't being too stressed.
    The signal is preconditioned in that it goes through a buffer.....this puts the AC signal on a DC level of half VCC (necessary to full wave rectify the signal inside the PIC).
    At the end of the day, I'm really just using the latent (otherwise wasted) power of the in-situ modest PIC to save on a few components (not for cost, but space) - .I don't want to start involving specific specialised ICs for what is after all a simple enough requirement.
    oh, btw I've no problem with the title being changed!
    Quote Originally Posted by languer View Post
    Hank, take a look at the Tips & tricks doc (http://ww1.microchip.com/downloads/e...Doc/01146B.pdf). Pay special attention to chapter3 (CCP and ECCP); tips #7 and #11.
    wow...a great doc.....need to digest - thanks!
    Mar 2009
    Eeek, even a little bit of code like this....
        toggle PortC.4   'pin 6
        'count1 = count1 +1
        present_sample = ADRESH
        IF  present_sample < 128 then
        present_sample = (127 - present_sample)
        present_sample = present_sample -128
        IF present_sample >= rolling_peak THEN
        rolling_peak = present_sample
        if count1 =  50 and rolling_peak !=0 then
        rolling_peak = rolling_peak -1
        count1 = 0
    is only toggling at 16khz - meaning that the main loop is only running at 30khz ...gulp (that's not leaving much room for anything else) bearing in mind I only have a 20khz sample rate going on...I wish the 16f1828 didn't have the ADC iissue about 8Mhz internal clock, becuase the obvious way of winning back por main loop time is to crank the internal clock up.
    Aug 2010
    Maryland, USA
    Default Re: Low frequency audio level detector using PIC ADC?
    what is your device ID and REV?
    -Bert
    USA - Arizona
