That's a good call (as ever) Bert - I shall try it tonight.
Since I can't get to the bottom of ensuring the sample rate *is* what I *hope* it is....last night, I tried the good old 'tried & tested' ...send the max audio frequency I'm interested in (1.5khz) then tweak the TMR 'match against' CCPRxH, CCPRxL registers (sample rate) until I saw static ADC readings. From recollection it was about CCPR4l = 100 (which I think works out at 20khz sampling)...which is 13 samples throughout the waveform ....albeit this was with a slower decrement (pseudo capacaitor discharge rate). As I type this, that doesn't seem enough samples in the light of the stable readings I was seeing. Hmmm.
I really can't figure out what's going on with the toggling CCP4 output pin (the whacky square wave)...30Hz?!!!
Can anyone think of an alternative method of confirming the special event trigger frequency?!!
I've now got a fresh challenge-ette with this method ...the dependency (stability) of it very much depends on the time it takes for my main loop....obviously the ADC register is getting updated at the sample rate (in the background), but if I don't copy the ADRESH register into my my main loop & then process it 'in between' subsequent samples then I'm in trouble - therefore I need to establish a way of seeing exactly how much time my main loop is taking (ie so I know when I've gone past the time allowed between samples) .....how best to approach this? (my immediate thought is a timer count between loops & convert the timer value to human time that I can see onscreen?!!)
