Low frequency audio level detector using PIC ADC?
Results 1 to 40 of 69
    Mar 2009
    Default Re: Low frequency audio RMS signal level detector using PIC ADC?
    I don't see how to set this up for 40Mhz. At any rate, what speed are you running?
    Do you have a free pin to toggle each interupt to see exactly what the frequency is? While I agree the seeming like 1K is a far cry from 10K, but for me I just like to know for sure to fine tune it.
    Also as a suggestion, DT pointed me to TMR2 and the use of the PR register. The advantage is no reloading of the preload. it also has pre and post scaling to turn your 8 bit counter into a slower counter.
    Now for more confusion, your preload will give you 32 instructions before overflowing. I think you have that in the int handler itself. not that it will matter, but if you are running at 32 Mhz, 4uSec timing, or 250KHz. So maybe you are flooding HSEROUT?
    Hi Bert.
    Yeah, I got carried away with the max Osc value this pic can run at - it's 32Mhz.
    that said, I'm only running it at 8Mhz (there an errata sheet out that says early versions of this PIC had probs with ADC above 8Mhz clock - so I'm staying on the safe side)
    Good call about the toggle - I've put a toggle pin line in the interrupt handler, my scope measures the square wave at 2.66Khz, but I'm assuming the interrupt rate is double that? (half, the time low, half the time high)...therefore I've an interrupt frequency of about 5Khz
    I'll have a a go with Timer2, but the PICcalc timers that abound are doing my head in! :-)
    Edit:
    Just tried timer2...
    @ __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF & _LVP_OFF
    @ __CONFIG _CONFIG2, _LVP_OFF
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    Osccon = %01110010      'Osc 8Mhz
    DEFINE  OSC 8
    Now the timer2 settings...
    'Timer2 Registers:
    'Prescaler=1:1; TMR2 PostScaler=1:1; PR2=66 - Freq = 30,303.0303Hz - Period = 33,000 ns
    T2CON.6       = 0 ' bits 6-3 Post scaler 1:1 thru 1:16
    T2CON.5       = 0
    T2CON.4       = 0
    T2CON.3       = 0
    T2CON.2  = 1 ' Timer2 on bit: 1=Timer2 is on;
    T2CON.1 = 0 ' bits 1-0  Prescaler Rate Select bits
    T2CON.0 = 0
    T2CON = %00000100
    PR2 = 66            ' PR2 (Timer2 Match value)
    Now the interrupt routine...
    ADC_Sample:
    @ INT_DISABLE  TMR2_INT     ; enable Timer 0 interrupts
        toggle PortC.3
        ADCIN 8, Signal_In                'sample the incoming signal
        IF SIGNAL_IN > 130 THEN           'a level of 128 is the zero crossing point (130 adds a bit of margin for error)
        zero_cross = 1                    'a simple toggle flag to track whether we're above zero or below
        IF SIGNAL_IN > PREVIOUS_SAMPLE THEN previous_sample = signal_in     ; if this latest incoming sample is bigger than the last then it supercedes the prvious value
        GOTO INTERRUPT_END
        if signal_in < 126 and zero_cross = 1 then  'if sample is 128 or less, then we're at the zero cross point, (126 adds some margin for error) therefore we've finished trying to sample peak
        peak_sample = previous_sample               ' our peak sample is therefore whatever value is in the variable 'previous_sample' from above
        previous_sample = 0                         'zero it, ready for when the waveform goes into positive territory again.
        zero_cross = 0                             ' toggle the above zero/below zero flag
        INTERRUPT_END:
        LOOP_COUNT1 =LOOP_COUNT1+1
        if loop_count1 = 100 then
        hserout [dec signal_in,9,dec peak_sample,13, 10]
        loop_count1 = 0
    @ INT_ENABLE  TMR2_INT     ; enable Timer 0 interrupts
    @ INT_RETURN
    Still just seeing 5khz 'interrupt frequency' on my scope (this is the pin I'm toggling in the interrupt routine)...
    AaaaaaarrrrrggggghhhhhHHHH!!!!!!!
    Aug 2010
    Maryland, USA
    Hank WAIT!!! (drama over)
    Before you change anything, play with your preload. you still only have 32 instructions between interupts. Do you understand why?
    Timers are this: they always count up and flag int when they rollover to 0. when set up to clock from fosc/4, this means 1 count per ASM instruction. so you are at 2Mips, so (1/2,000,000)*count is your int frequency. in your case count = 32 which = 16uSec. or 62.5K.
    So the question is why is yours 5.32K? I believe it is because you are actaally taking longer to get there AND longer in the int, so your numbers are skewed.
    Play with the preload until you get numbers that make sense. Then work from there.
    -Bert
    Mar 2009
    Ok, so in the light of your point about taking longer in the interrupt routine, I went back to basics...
    ADC_Sample:
        toggle PortC.3
    @ INT_RETURN
    This gives me an interrupt frequency of 11.44khz (ie 5.72khz on the scope)...so my interrupt routine is severely skewing my interrupt! (told you I sucked!)
    It's late here in the UK...need to sleep on this one - many thanks for your help.
    Mar 2009
    Having slept on this....think I'm gonna have to give this one much more thought.
    Not the interrupt frequency problem (btw - Bert, I think you were right...put the peak detect code in the main loop!), but I noticed late last night that for the above code 'trapped' the peak of a nice sigen sine wave very well, a real life guitar signal caused problems. Basically, a guitar signal is full of harmonics...so you've not just got a fundamental going on, you've got strong second harmonic immediately after a string has been plucked - these harmonics are lower in signal magnitude & worse still, force the signal to cross zero too - which plays havoc with the larger fundamental peak detect bit.
    I guess what I really need is a slick bit of code that acts like a diode with a smoothing cap following on - there's probably a role to play with DTs averaging routines here!
    Something along these lines...
    1. Is present ADC sample larger than last ...if so then store it (that'll be the diode bit)
    2. When cycle crosses zero, then largest sample from the logic above is the peak.
    3. Have a rolling average for all the peaks (that'll be the capactor/LPF bit)
    One to mull.
    Aug 2010
    Maryland, USA
    Quote Originally Posted by HankMcSpank View Post
    Hank, this still bothers me.
    Can you try this:
    BMAIN:  'make this your new temporary main for this test
     LATC = LATC ^ %00001000 ' this assumes you can use portc.4 as an output.
     GOTO BMAIN
     'new ISR
    LATC = LATC ^ %00000100 ' this will toggle portc.3
    the point here is main will just toggle portc.4 and the ISR will toggle portc.3. When you scope these, we will see the speed at which you are running. We expect main to be ~4 instructions, maybe 6. so that would give C.4 a frequency of .5M (.25M) and the ISR should interupt every 7 or 8th time through main.
    Last edited by cncmachineguy; - 17th February 2011 at 13:23. Reason: Fixed frequency for 8M osc
    -Bert
    Mar 2009
    Hi Bert,
    Sure, I will certainly try that (it troubles me & I'd like to understand why I'm not getting the interrupt frequency that I should), but it won't be until tonight after the kids have been put to bed! I'm in the UK, so it'll probably be about 5.00pm EST when I have some results.
    USA - Arizona
    I am no fan of doing the RMS thing on the PIC itself, but in any case you probably be better served by having the CCP module trigger the ADC conversion. That way you get a very precise sampling rate (look at section 15.2.5 SPECIAL EVENT TRIGGER of the datasheet).
    Aug 2010
    Maryland, USA
    Oh Thats a pretty sneaky way to do it. (BTW, section 16.2.5 not 15.)
    @Hank, are you by any chance using this in the same applaction as the phase do-hicky you were working on a little while back? Seems if so, you may already have the parts in place for the trigger.
    -Bert
    Mar 2009
    languer - tks, I'd actually seen that previously in the datasheet, but couldn't immediately work out how to apply it, then I forgot about it.
    Bert - phase project has been parked up.
    Meanwhile, this ongoing problem is going to turn out so easy that I'll never be able to show my face on here again.
    Ok, the latc didn't work, so I'm using a basic toggle, here the stripped back code...
    @ __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF & _LVP_OFF & _CLKOUTEN_OFF
    @ __CONFIG _CONFIG2, _LVP_OFF & _PLLEN_OFF
    DEFINE  OSC 8
    DEFINE  NO_CLRWDT 1   ' PBP doesn't clear WDT automatically
    '16F1828 Pin Connections*********************************************
    TRISC.4 = 0     '6   RC4      Main Output
    CM1CON0 = 0   ' COMPARATORS OFF
    CM2CON0 = 0   ' COMPARATORS OFF
    ADCON0 = 0
    ADCON1 = 0
    ANSELA     = 0          ; All Port A ports to be digital
    ANSELB     = 0          ; All Port B ports to be digital
    ANSELC     = 0          ; All Port B ports to be digital
    txsta = %10100100  'needed to turn on pin 10 as valid HSerout pin.
    WPUA = 0        'weak pullups disabled.
    WPUB = 0        'weak pullups disabled.
    WPUC = 0        'weak pullups disabled.
    'Timer2 Registers:
    T2CON.5  = 0
    T2CON.4  = 0
    T2CON.3  = 0
    T2CON.0  = 0
    INT_LIST  macro ; IntSource,    Label,         Type, ResetFlag?
        INT_Handler   TMR2_INT,  _Bert_ISR,   PBP,  yes
        INT_CREATE       ; Creates the interrupt processor
    ;----[Main Program Loop]------------------------------------------------------------------
     toggle portc.4   'pin 6   (blue scope trace)
     'LATC = LATC ^ %00001000 ' this assumes you can use portc.4 as an output.
     GOTO BMAIN
     '---[TMR2 - interrupt handler]--------------------------------------------------
    Bert_ISR:
        toggle PortC.3   'pin 7 (yellow scope trace)
        'LATC = LATC ^ %00000100 ' this will toggle portc.3
    @ INT_RETURN
    & here's the result....
    green trace is the main loop toggle (port C.4) with a frequency of just 1kHz(!!!) & the yellow trace is the ISR toggle (port C.3)with a frequency that's higher at 12Khz(!!!) , I have not got one clue what is going on here - it feels like 'week one - intro to PICs' all over again!
