Low frequency audio level detector using PIC ADC?
Results 1 to 40 of 69
Threaded View
  1. #11
    Mar 2009
    Default Re: Low frequency audio RMS signal level detector using PIC ADC?
    Hank,
    1. why don't you make a full rectifier of your analog signal?
    2. is the signal always of the same amplitude?
    3. are you after a peak detector or an rms calculator? I am little confused by this thread...
    Hi Ioannis,
    Ok, I came into this thinking I needed an RMS detector - I don't (despite the title ....which I'm unable to update/edit)....I really want to track 'peak' of a guitar signal. The incoming signal is of very wildly differing amplitude.....but fortunately it only goes up to 1.5khz max (the max fundamental on a guitar...I don't care about the harmonic content here - I'm only wanting to extract magnitude info, not accurately replicate the waveform digitally)
    So why not use conventional analogue components? Well I'm *very* pushed for PCB real estate ...the intended PCB will already have a PIC, but the PIC isn't doing much (basic switching, LED indicators etc) ...so that got me thinking, why not extract peak from the incoming analogue signal using the PIC - just like an analogue full wave rectifier into a peak detector (which is what my code above is doing ....'full wave rectifying a signal' but via code inside the PIC) ...if nothing else, my intention was to learn a little more about sampling an AC signal rapidly .....& like most journeys - you discover other stuff enroute. And that has proved to be the case - the special event trigger - it's been a revelation to me at least.
    Not only do I save components (PCB space)...I also avoid the forward voltage drop loss that an analogue peak detector suffers from (this is a relatively small signal I'm monitoring)...but it struck me I can also have on the fly varying 'discharge' rates to suit as my peak detector is now working in the digital domain.
    The nut has actually been cracked ....all that's happening here now is a bit of a wash up...trying to get to the bottom of a couple of quirks I'm hitting (specifically the calculations wrt sample rate, etc)
    Bert,
    Again...great ideas...I'll implement this later to get a handle on the sampling frequency (I concur that the datasheet is a bit scant with the 'meat' here!)
