Low frequency audio level detector using PIC ADC?
Results 1 to 40 of 69
Threaded View
  1. #31
    Mar 2009
    Default Re: Low frequency audio RMS signal level detector using PIC ADC?
    You thought I was done here didn't you?!
    Well for this to be 100% dependable, I need to be assured I know what the hell is going 'behind the scenes' with respect to this special event trigger melarkey.specifically whether the sample rate can be easily worked out & dependable.
    Firstly...I've accounted for the ADC value 'jitter' - the incoming audio ignal is jittering! (this means it's not a measurement error...but the actual signal itself is varying. This is very heartening as it means this thing has real potential!)
    Ok, something troubles me here, this from the datasheet.,..
    "The Special Event Trigger output of the CCP occurs immediately upon a match between the TMR1H, TMR1L register pair and the CCPRxH, CCPRxL register pair. The TMR1H, TMR1L"
    At 8MHz, therefore a 2MHz instruction clock that presetting 50 for TMR1L to match against would - if I have the maths/theory correct - mean a a 40khz special event trigger rate......but if that were the case, I'd have expected to seen the ADC samples be ing far more erratic at an audio input signal 20khz than what I'm seeing (two samples during the 20Khz waveform would have ADC results all over the place) ...so what's going on?
    I looked at the datasheet, and apparently it's possible to get the special event trigger to toggle a pin (as opposed to take an ADC sample) ...at least in that way, I could the put a scope on to the physical pin confirm the observed frequency vs the number preloaded into the CCPRxH, CCPRxL pair. I'll revisit this over the coming evenings, but if anyone has had prior dealings with the special even trigger & specifically getting it to toggle a pin - all top tips greatfully received! Here's what I'm seeing on the CCP4 pin (I've set the pin as an output)....
    (thats doesn't look like a good square wave at all!)
    & here's the register I'm setting....
    CCP4CON = %0000010
    Also, can someone clear up this ADC uncertainty for me.....Fosc/8 & tads...there's a table on page 149 of the datasheet here http://ww1.microchip.com/downloads/e...Doc/41419A.pdf but it's not clear to me how many tads an 8 bit ADC sample will take (10 bits would appear to be 11.5...therefore 12us?!)....basically I want to know how long an ADC sample takes...as obviously this will dictate the maximum sample rate I can get the special event timer to run at.
