Hank, 2 things to try. First turn off use PBP in the int setup. check the output. then change pr=200. no reason for the value, just much larger. You don't need to post the Scope unless you want. I am happy with just the numbers right now.
Code:INT_Handler TMR2_INT, _Bert_ISR, PBP, yes becomes INT_Handler TMR2_INT, _Bert_ISR, ASM, yes
