portb input problems
Results 1 to 2 of 2
    Feb 2011
    Default portb input problems
    i cant get my portb pins working as inputs, any help?
    digit1 var portd.0
    digit2 var portd.1
    digit3 var portd.2
    digit4 var portd.3
    digit5 var portd.4
    digit6 var portd.5
    cnt var word
    digit var byte
    pattern var byte
    i var word
    first var byte
    second var byte
    third var byte
    fourth var byte
    fifth var byte
    sixth var byte
    mills var word
    seconds var byte
    mins var byte
    hour var byte
    ampm var portb.7
    parker var byte
    num1 var portb.6
    num2 var portb.5
    num3 var portb.4
    num4 var portb.3
    num5 var portb.2
    num6 var portb.1
    num7 var portb.0
    num8 var portc.4
    num9 var portc.5
    num0 var portc.6
    seconds=45
    mins=59
    hour=11
    mills=1
    cnt=0
    INTCON=%10100000
    OPTION_REG=%00000000
    TMR0=6
    on interrupt goto isr
    INTCON=%10100000
    trise=1
    trisa=0
    trisd=0
    trisb=%11111110
    trise=1
    trisc=1
    ampm=1
    parker=0
    loopa:
    if portc.3=1 then
        mills=mills+1000
        while portc.3=1
        wend
    if mills>59 then
        mills=0
        seconds=seconds+30
    if seconds>59 then
        seconds=0
        mins=mins+1
    if mins>59 then
        mins=0
        hour=hour+1
    if hour>11 then
        hour=1
        if parker=0 then
            ampm=0
            parker=1
         parker=0
            ampm=1
    goto loopa
    loopkeypad:
    if num1=0 then
    hour=1
    goto loopkeypad
    disable
    isr:TMR0=6
    digit=hour dig 1
    lookup digit,[$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F],pattern
    porta=pattern
    digit6=1
    pauseus 500
    digit6=0
    digit=hour dig 0
    porta=pattern
    digit5=1
    pauseus 500
    digit5=0
    digit=mins dig 1
    porta=pattern
    digit4=1
    pauseus 500
    digit4=0
    digit=mins dig 0
    porta=pattern
    digit3=1
    pauseus 500
    digit3=0
    digit=seconds dig 1
    porta=pattern
    digit2=1
    pauseus 500
    digit2=0
    digit=seconds dig 0
    porta=pattern
    digit1=1
     pauseus 500
    digit1=0
    cnt=cnt+1
    intcon.2=0
    resume
    enable
    Default Re: portb input problems
    ampm var portb.7
    trisb=%11111110
    Making "ampm" an input.
    But then you are writing to "ampm" as an output.
    ampm=1
