beginers-how to escape from loop
Results 1 to 6 of 6
    Mar 2009
    Default beginers-how to escape from loop
    ok here it is i want to escape and go sub from this loop but seems that nothing is working for me!!!
    Clear ' ocisti sve varijable
    Low PORTD.0  ' usli smo u mod za prikaz poruke
    a=14
    k=120
    j=0
    leddata[0-13] = $00             ' varijabla ledadta od 0 do 13 je 00
    For b = 0 To 11                 ' moguci broj slova u poruci
        For i = 0 To 4
            c=i+a                   'povecaj a=14-19; a=20-24; a=26-30 itd...
            d=i+j+k                   'povecaj j=120-124; a=126-130; a=131-135 itd...
                leddata [c]= ERead d	'filuj ledadtu od 14 do max broja slova za prikaz iz eeproma pocevsi od 120 pa nadalje
                DelayUS 20
        Next
        leddata [a+5]=ERead 119   'upisi prazanu kolonu izmedju slova
          a=a+6
          j=j+6
     Next
           For scroll = 0 To c      ' skrolaj poruku c zadnji leddata
             For scan = 0 To 35
                      PORTC.1 = 1   'reseting 4017
                      PORTC.1 =0
    			For kolona = 0 To 14  'broj kolona
    				PORTC.0 = 1       'clock 4017
                    PORTC.0 =0
                    PORTB = leddata[kolona]
    				DelayUS 250
                    PORTB=0
    		    Next
             Next
             For brojac = 0 To (c-1)
            leddata[brojac]=leddata[brojac+1]' pomjeri za jedan
            Next
            Next
    GoTo main
    Default Re: beginers-how to escape from loop
    What exactly is it you are trying to do?
    I would always place the variable after NEXT command, just to be sure.
    But exiting the FOR-NEXT loop never was a problem.
    Mar 2009
    thx well i solved it with this piece of code, i forgot basic stuff ...
            If PORTD.1=1 Then
                    GoSub odaberporuku
        	 	     Break
        	 	End If
    Break ???
    There is no such command in PBP...
    Nor those ones :
     leddata[0-13] = $00
     DelayUS 20
    Mar 2009
    yeah you are right this is from ProtonIde compiler...
