Internet Connected PIC and Push notification to iPhone
Results 1 to 6 of 6
    Feb 2005
    Essex, UK
    Default Internet Connected PIC and Push notification to iPhone
    Haven't been here for a while, but a recent Arduino project got me thinking to see if the same was possible using a PIC.
    It basically uses a Arduino that is connected to the net to send push notifications to an iPhone when an event occurs.
    Here is the project.
    http://hacknmod.com/hack/arduino-bas...ur-smartphone/
    Having worked with PICs a while back, wanted to see if similar was achievable using a PIC instead of a Arduino.
    Nothing special there just a Serial to Ethernet module connected to the mcu.
    Feb 2005
    Essex, UK
    Thanks for your reply.
    Any suggestions that are cheap and have a small footstamp so more than one can be used in multiple projects.
    A module is a good alternative, but was wondering if there were component based options to add to a PCB with the MCU.
    Thanks again,
    I guess you could do the components if you had several to do. 100+ ?? Modules are tested and if you go wifi the FCC may have something to say ...
    This thread talks about a few options. Kind of long... http://www.picbasic.co.uk/forum/showthread.php?t=11883
    I use the ConnectOne for no real good reason...
    This is a demo I did. The code is not pretty but should be understandable...
    http://mackrackit.com/mac/ichip/ichip.html
    Dec 2005
    Quote Originally Posted by Tissy View Post
    http://www.picbasic.co.uk/forum/show...ethernet+stack
    Feb 2005
    Essex, UK
    Thanks for the relpy Dave.
    It appears a lot of the downloads are now not available and I'm surprised a lot of these articles are 3-5 years old.
    As the downloads are no longer working, wonder if anyone has these files?
    I am basically wanting a PIC to call a web php page from the Internet.
    So just need a simple solution of connecting a PIC to the Internet to 'call' this PHP. Once called the php script does the rest.
    Many thanks.
