HELP with PORTA PIC 16F628A
Results 1 to 3 of 3
Threaded View
  1. #3
    May 2008
    Italy
    Default Re: HELP with PORTA PIC 16F628A
    Your column 5 doesn't work simply because PortA.4 is a Schmitt Trigger
    input and an open drain output. You will need an additional NPN transistor with a pull down resistor to make column 5 working.
    Cheers
    Al.
    PS adding CMCON = 7 on top of your code, will disable the comparators function.
