HELP with PORTA PIC 16F628A
Results 1 to 3 of 3
    jams90's Avatar
    jams90 Guest
    Question HELP with PORTA PIC 16F628A
    Im newbie to microcontrollers and picbasic and i'm trying to drive a simple 5x7 led matrix with an 16f628A, i connect the PORTB to the rows and PORTA from PORTA.0 to PORTA.4 to the columns
    but the 5th column doesn't show anything.
    It's a single 5x7 led matrix.
    here's the code:
    DEFINE INTOSC
    TRISA=0
    TRISB=0
    loop:
    PORTA.0 = 1
    PORTB = %01111110 'COLUM DATA
    pause 2
    PORTA.0 = 0
    PORTA.1 = 1
    PORTB = %01111110
    PAUSE 2
    PORTA.1 = 0
    PORTA.2 = 1
    PORTB = %00000000
    PAUSE 2
    PORTA.2 = 0
    PORTA.3 = 1
    PORTB = %01111110
    PAUSE 2
    PORTA.3 = 0
    PORTA.4 = 1
    PORTB = %01111110
    PAUSE 2
    PORTA.4 = 0
    GOTO loop
    i know it could be made easier but im just experimenting with PICBASIC
    I wanna make PORTA all DIGITAL OUTPUT
    can someone help me?
    i just wanna make it show "TE AMO MAMA" letter by letter on the 5x7 led matrix
    Default Re: HELP with PORTA PIC 16F628A
    May 2008
    Italy
    Your column 5 doesn't work simply because PortA.4 is a Schmitt Trigger
    input and an open drain output. You will need an additional NPN transistor with a pull down resistor to make column 5 working.
    Cheers
    Al.
    PS adding CMCON = 7 on top of your code, will disable the comparators function.
