Pwm portb in pic 16f628 in same time
Results 1 to 23 of 23
    Default Re: Pwm portb in pic 16f628 in same time
    Perhaps I am missing something.
    The code you show in post # 4 has no DT_INTS include file. It does have an include file named Multi_SPWM.pbp , which I gather is really SPWM_INT.BAS from this link: http://www.darreltaylor.com/DT_INTS-14/SPWM_INT.bas.txt .
    If this is correct, then you should have an include in your file for DT_INTS, really I think that is the only way to get a WSAVE error, but I could be wrong.
    Your might try something more along the lines of the example code, here: http://www.darreltaylor.com/DT_INTS-14/SPWM.html with both include files, etc. If you get a wsave error, make sure you are editing the right DT_INTS_14.bas file, whatever you call it in your include statement.
    For your chip, it should be edited so that:
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    EDIT: A little late, but I found where Multi_SPWM.pbp came from http://www.pbpgroup.com/modules/wfse...p?articleid=12
    Last edited by ScaleRobotics; - 14th February 2011 at 01:25. Reason: a little late, but found Multi_SPWM.pbp
    May 2010
    Yes,I have DT_INTS_14.bas file,I write correct name.
    I do what you tell me,but now I have errors.
    If I understudy you,i MUST WRITE THAT,CODE?
    ' Comment them out to fix the problem ----
    I do that but I have errors when I compile.
    This program in my PicBasic :
    '*  Name    : Test_SPWM.pbp                                     *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 9/30/2006                                         *
    ; Initialize your hardware first
    DEFINE OSC 20
    CLEAR
    INCLUDE "DT_INTS-14.bas"         ; Base Interrupt System
    INCLUDE "SPWM_INT.bas"              ; Software PWM module
    DEFINE SPWM_FREQ  40                ; SPWM Frequency
    DEFINE SPWM_RES   256               ; SPWM Resolution
    DutyVars   VAR BYTE[3]              ; DutyCycle Variables
      DutyVar1 VAR DutyVars[0]          ; group them in an array for easy access
      DutyVar2 VAR DutyVars[1]          ; with FOR loops etc.
      DutyVar3 VAR DutyVars[2]
    SPWM_LIST  macro                    ; Define PIN's to use for SPWM
         SPWM_PIN  PORTB, 0, _DutyVar1
         SPWM_PIN  PORTB, 1, _DutyVar2
         SPWM_PIN  PORTB, 2, _DutyVar3
      SPWM_INIT  SPWM_LIST              ; Initialize the Pins
            INT_Handler   TMR1_INT,  SPWMhandler,  ASM,  yes
        INT_CREATE                      ; Creates the interrupt processor
    @ INT_ENABLE  TMR1_INT              ; enable Timer 1 interrupts
    ;_____________________________________________________________________________
    RandVar   VAR WORD : RandVar = 12345
    LoopCount VAR WORD
    wsave   VAR BYTE    $70     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
                                   ; Simple Demo to fade/flash some LED's
        DutyVar1 = 5                        ; Start with 3 LED's at different
        DutyVar2 = 50                       ; brightness
        DutyVar3 = 150
        pause 3000
        FOR LoopCount = 1 to 4              ; Reapeat 4 times
            for DutyVar1 = 0 to 150         ; Fade LED1 UP
                pause 10
                RANDOM  RandVar
                DutyVar3 = RandVar & $3F          ; Give LED3 a random dutycycle
            next DutyVar1
            for DutyVar1 = 150 to 0 STEP -1 ; Fade LED1 Down
                pause 10
                RANDOM  RandVar
                DutyVar2 = RandVar & $3F         ; Give LED2 a random dutycycle
            next DutyVar1
        NEXT LoopCount
    GOTO Main
    is correct?
