Newbe: Nested For..Next loops problem
Results 1 to 7 of 7
    Jan 2010
    Default Newbe: Nested For..Next loops problem
    Hi Guy's
    I'm having problems with MCSP and PBP reporting a for..next loop error for the code below.
    the error reported is:
    'Error Line 94: FOR without matching NEXT. (sampling.pbp)
    'Error Line 96: FOR without matching NEXT. (sampling.pbp)'
    These are the For index.... and For index2.... in my code.
    But i can see the two next statements and they are in line.
    I have even but then together before cutting and pasting my code in between. What am I doing wrong?
    The code below is some not elegant code I'm starting to work on, where I would like to take 10 samples for each of three sensors, hence the need for a 10 way loop within a 3 way loop.
    I'm sure there is a better way of doing it, but i'm learning at the moment and trying things out.
    Eventually I want to record the highest and lowest two reading, drop these and average the remaining 8 samples. Only if I get a valid reading (DS18B20 temp sensors)
    mainloop:
    For index = 1 to 3 step 1                                   ; read 10 values for 3 sensors
        FOR index2 = 1 to 10  step 1                            ; Take 10 reading
            IF temp_val[index2] < temp_val_lo[index] then       ; is readlng lower than lowest
                temp_val_lo[index] = temp_val[index2]           ; update lowest
                temp1[index] = temp1[index] + temp_val[index2]  ; add reading to running total
            ELSE IF temp_val[index2] > temp_val_hi[index] then  ; is reading higher than highest
                temp_val_hi[index] = temp_val[index2]           ; update highest
            ELSE                                                ; if reading not highest or lowest
        NEXT index2                                             ; update next reading
    NEXT index                                                  ; update next sensor
    GOTO mainloop
    Jan 2010
    Default Re: Newbe: Nested For..Next loops problem
    Sorted it!
    It was another issue lower down in the code, a missing ENDIF causing the compiler not to find the the two NEXT statements.
    It was really bugging me for a while. Should have had a cup of coffee and re-look at the code.
    Lesson learned !
    Thank for the forum space
    Hi, Biggazzzz
    3 sensors ???
    could also be written
    mainloop:
    For index = 1 to 3                                          ; read 10 values for 3 sensors
        FOR index2 = 1 to 10                                    ; Take 10 reading
    GOTO mainloop
    as you add temp1[index] to total whatever the value ...
    Jan 2010
    Cheers Alain,
    Anything to make the code look better and save code space
    Having a bit of a problem with the final maths i.e. dropping the highest and lowest readings and divide result 8.
    for some reason result (636) // 8 is giving be 0.4 and not 0.5 as expected. I'm still working on it before I bail out and ask why here
    I'm sure you've figured it out by now but the // operator returns the "reminder". When you // by 10 this happens to be what would be on the right hand side of the decimal point but when // by 8 it's not.
    (636/8=79.5)
    636 / 8 = 79 and 636 // 8 = 4 because 79*8+4=636
    (636 / 10 = 63.6)
    636 / 10 = 63 and 636 // 10 = 6 because 63*10+6=636
    Jan 2010
    thanks guy's
    I was going for the following
    636 was the running total of 10 samples minus the highest and lowest. That left 8 samples.
    I therefore wanted to divide 636 by to get 79.5.
    I ended up multiplying by 50 and diving by 4, then handle the digits either side of the decimal place (see example) it's work in progress, but welcome any pointers
    temp_val[1] = 100                   ; real tempeture 10.0c
    temp_val[2] = 115                   ; 11.5c
    temp_val[3] = 122                   ; 12c etc...
    temp_val[4] = 139
    temp_val[5] = 150
    temp_val[6] = 130
    temp_val[7] = 80
    temp_val[8] = 100
    temp_val[9] = 115
    temp_val[10] = 252
    ' total = 1301
    ' lowest = 8.0c
    ' highest = 25.2c
    ' middle 8 samples = 971
    ' average of the 8 sample = 121.1375 or 12.137c
    ;----[Main Program]---------------------------------------------------------
    mainloop:
    'index = 0
    'index2 = 0
    temp1[1] = 0
    temp1[2] = 0
    temp1[3] = 0
    for index = 1 to 3 step 1                                   ; Take 10 sampels from 3 sensors
        For index2 = 1 to 10  step 1                            ; Take 10 reading
            IF index2 = 1 THEN
                temp_val_lo[index] = temp_val[1]                ; Set initial lowest reading to first reading
                temp_val_hi[index] = temp_val[1]                ; Set initial highest reading to first reading
            LCDOUT $fe,1,"Sensor ",DEC index, " Data ",DEC index2
            if temp_val[index2] <= temp_val_lo[index] then      ; If readling lower than lowest
                temp_val_lo[index] = temp_val[index2]           ; Update lowest
            elseif temp_val[index2] => temp_val_hi[index] then  ; If reading higher than highest
                temp_val_hi[index] = temp_val[index2]           ; Update highest
            ENDIF                                               ; Else reading is not highest or lowest and....
                temp1[index] = temp1[index] + temp_val[index2]  ; Add reading to running total
        next index2                                             ; Update next sample
            temp1[index] = temp1[index] - temp_val_hi[index]    ; Subtract the highest reading
            temp1[index] = temp1[index] - temp_val_lo[index]    ; Subtract the lowest reading
            temp1[index] = (temp1[index] * 50)/4                ; Get rid of the decimal places
            LCDOUT $FE,1, "Sensor = ",DEC index
            LCDOUT $FE, $C0,"Temp = ",DEC temp1[index] DIG 4, DEC temp1[index] DIG 3,".", DEC temp1[index] dig 2, dec temp1[index] dig 1, dec temp1[index] Dig 0
            PAUSE 2000
    next index                                                  ; update next sensor
    PAUse 5000
    goto mainloop
    Quote Originally Posted by Big Gaz View Post
    Sorted it!
    Exactly what FinelineIDE is for.
    Red "O" is for orphan.
    Norm
