here is my code
Code:mainloop: for index = 1 to 3 step 1 ; read 10 values for 3 sensors For index2 = 1 to 10 step 1 ; Take 10 reading if temp_val[index2] < temp_val_lo[index] then ; is readling lower than lowest temp_val_lo[index] = temp_val[index2] ; update lowest temp1[index] = temp1[index] + temp_val[index2] ; add reading to running total else if temp_val[index2] > temp_val_hi[index] then ; is reading higher than highest temp_val_hi[index] = temp_val[index2] ; update highest temp1[index] = temp1[index] + temp_val[index2] ; add reading to running total else ; if reading not highest or lowest temp1[index] = temp1[index] + temp_val[index2] ; add reading to running total next index2 ; update next reading next index ; update next sensor goto mainloop
