6 HPWM signal generation with PIC18F4431
Results 1 to 23 of 23
    Default Re: 6 HPWM signal generation with PIC18F4431
    Ok, a little update.
    I've tested the program on the real PIC with an oscilloscope. All of the output signals are correct, but the sine cycle is very slow (about 4 seconds to make a complete sine period, so f=1/4=0,25Hz).
    The PWM frequency seems correct (3,245kHz).
    I've defined correctly the configuration fuses (or bits), with "HS oscillator" setting, because I'm using a 40MHz quartz oscillator connected to OSC1/OSC2 pins with 22pF ceramic capacitors.
    The code (note I'm not using the FOR... NEXT loop in this case, like the upper programs, it's a lot faster if I use the FOR... NEXT loop, but I don't know why) :
    'PIC initialization
    DEFINE OSC 40
    DEFINE LCD_EREG PORTD
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    'DT interrupt system include
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
    'Port registers configuration
    PORTB=%0          ' Clear ports
    TRISB=%11000000   ' PWM 0,1,2,3,4,5 outputs
    'PCPWM registers configuration
    DTCON=%110        ' Deadtime (600ns)
    PTCON0=%100       ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
    PTCON1=%10000000  ' PWM time base is ON, counts up, 19.45kHz/4
    PTPERL=%0         ' PWM low-side
    PTPERH=%1         ' PWM high-side
    'PWM registers configuration
    PWMCON0=%1000000  'PWM 0,1,2,3,4,5 set in pair mode
    PWMCON1=%1        'PWM timer sync configuration
    'Interrupt processor
    INT_LIST  macro    ; IntSource, Label, Type, ResetFlag
            INT_Handler   TMR1_INT,  _pwmint,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    'Timer configuration
    T1CON=%10000001            ; Prescaler = 1:8, TMR1ON, 16-bit counter
    @ INT_ENABLE  TMR1_INT     ; Enable Timer 1 interrupts
    'PWM calculation variables
    uduty VAR WORD     'U phase duty
    vduty VAR WORD     'V phase duty
    wduty VAR WORD     'W phase duty
    dutydiv var WORD   'Frequency diviser
    dutymul VAR WORD   'Duty multiplier
    t VAR byte         'Incremental value
    'Variables definition
    dutydiv=0       'Range : 0-65535
    dutymul=65535   'Range : 0-65535 (for exemple, 32767=0.5)
    t=%0            'T initial value
    'Main program loop
    mainlp:
    HIGH PORTA.0
    LOW PORTA.0
    goto mainlp
    'PWM calculation and update interrupt
    pwmint:
        'Frequency diviser
        pauseus dutydiv
        'PWM U, V, W phases calculation
        uduty=(((sin(t)+%01111111)*%100)**dutymul)+%100
        vduty=(((sin(t+%01010101)+%01111111)*%100)**dutymul)+%100
        wduty=(((sin(t+%10101010)+%01111111)*%100)**dutymul)+%100
        'PWM U phase update
        PDC0L=uduty.LOWbyte
        PDC0H=uduty.HIGHByte
        'PWM V phase update
        PDC1L=vduty.LOWbyte
        PDC1H=vduty.HIGHByte
        'PWM W phase update
        PDC2L=wduty.LOWbyte
        PDC2H=wduty.HIGHByte
        'T variable verification and incrementation
        if t<%11111111 then
        t=t+%1
        t=%0
    @ INT_RETURN
    I think it's a TIMER problem (TMR1 is at 32kHz, isn't it?)
    Yes, it's probably a timer problem. You have TMR1 set up to derive its clock from the main oscillator (Fosc/4) so 10Mhz in your case. (Your code comments says you have a prescaler of 8 but you don't - it's 1:1.
    TMR1 is a 16bit timer and generates an interrupt when it overflows from $FFFF to $0000. In your case this means that the interrupt frequency is 10MHz/65536 = 152.6Hz. In other words, the pwmint interrupt service routine is executed 156 times per second.
    If a complete sinus cycle consists of 256 "steps" you should get a frequency of 152.6/256=0.6Hz but you claim 0.25Hz so I'm not sure what's going on exactly.
    If you want to speed up the frequency you must increase the interrupt frequency. You do this by preloading TMR1 in the interrupt service routine so that it doesn't have to count all the way from 0. If you, for example, preset it to 32768 you'll get twice as many interrupts per second as when letting it free run.
    Thanks Henrik, now I use TMR1L and TMR1H registers, I got a 40 Hz sine (it's better).
    I've heavly modified the code, I didn't use the SIN function anymore, but a lookup table with 72 values (5 degrees/value).
    Now, for debugging, I want to vary the timer value. For that, I use two buttons, one for increase (PORTC.4), one for decrease (PORTC.5), and then display the value to my LCD.
    The LCD works fine, but not the inputs. If I push the buttons, nothing happens. No increase or decrease. Same thing in the simulator.
    My code :
    ' PIC initialization
    DEFINE OSC 40
    DEFINE LCD_DREG PORTC
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE LCD_COMMANDUS 10000
    DEFINE LCD_DATAUS 1000
    ' BAS includes
    INCLUDE "Sine_table.bas"
    ' Port registers configuration
    TRISC=%00110000   ' +/- buttons
    ' PCPWM registers configuration
    PTCON0=%0         ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
    PWMCON0=%1000000  ' PWM 0,1,2,3,4,5 set in pair mode
    PWMCON1=%1        ' PWM timer sync configuration
    ' PWM calculation variables
    ustep var byte
    vstep var byte
    wstep var byte
    uduty var word
    vduty var word
    wduty var word
    timer var word
    amplitude var word
    carrier VAR word
    ' Variables definition
    ustep=72          ' 360 degrees phase angle
    vstep=48          ' 240 degrees phase angle
    wstep=24          ' 120 degrees phase angle
    timer=60950       ' Frequency adjust (60950=80Hz)
    amplitude=65535   ' Sinewave amplitude adjust (65535=max amplitude)
    carrier=1023      ' Carrier frequency adjust (1023=13kHz)
    ' PWM carrier frequency register configuration
    PTPERL=carrier.lowbyte
    PTPERH=carrier.highbyte
    ' Inverter startup
    pause 2000
    Lcdout $FE,1
    LCDOUT $FE,2,"Varidrive 1.0"
    LCDOUT $FE,$C0,"DR Electronique"
    pause 2000
    ' Interrupt processor
    INT_LIST  macro
            INT_Handler   TMR1_INT,   _pwmint,   ASM,  yes
        INT_CREATE
    ' Timer configuration
    T1CON=%1
    test var word
    test=1
    ' Main program loop
    mainlp:
    ' Debug display
    LCDOUT $FE,1
    LCDOUT $FE,2,"Timer var :"
    LCDOUT $FE,$C0,#test
    if PORTC.4=1 then test=test-1
    if PORTC.5=1 then test=test+1
    goto mainlp
    ' PWM calculation and update interrupt
    pwmint:
    ' Sinewaves frequency
    TMR1L=timer.lowbyte
    TMR1H=timer.highbyte
    ' PWM U phase calculation
    uduty=sine[ustep]
    uduty=uduty<<4**amplitude
    ' PWM V phase calculation
    vduty=sine[vstep]
    vduty=vduty<<4**amplitude
    ' PWM W phase calculation
    wduty=sine[wstep]
    wduty=wduty<<4**amplitude
    ' PWM U, V and W update
    PDC0L=uduty.lowbyte
    PDC0H=uduty.highbyte
    PDC1L=vduty.lowbyte
    PDC1H=vduty.highbyte
    PDC2L=wduty.lowbyte
    PDC2H=wduty.highbyte
    ' Phase angle calculation
    ustep=ustep-1
    vstep=vstep-1
    wstep=wstep-1
    ' Phase angle reinitialization
    if ustep=0 then ustep=72
    if vstep=0 then vstep=72
    if wstep=0 then wstep=72
    @ INT_RETURN
    The faulty code is in bold.
    Problem resolved, I will open a new thread.
    Dec 2012
    hello, i am new to this forum, I am final year electrical engg. student, my project is 'Speed control of Induction motor using PCPWM in PIC18f4431'. Plz guide me how to go about it, i want to write a code for sinusoidal PWM generation using PCPWM in edge aligned mode.
