6 HPWM signal generation with PIC18F4431
Results 1 to 23 of 23
    Default Re: 6 HPWM signal generation with PIC18F4431
    I'm not using a simulator, I just sent the values to the PC and plotted them with EXCEL. Here's the exact code I used to test with:
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DEFINE HSER_BAUD 19200
    i VAR BYTE
    T VAR BYTE
    uDuty VAR WORD
    vDuty VAR WORD
    wDuty VAR WORD
    For i = 0 to 2   'Make three periods
      T=0
       for T=0 to 255
       ' PWM U phase calculation
       uduty=((sin(t)+128)*4)
       ' PWM V phase calculation
       vduty=((sin(t+85)+128)*4)
       ' PWM W phase calculation
       wduty=((sin(t+170)+128)*4)
       HSEROUT [DEC uDUTY, ",", dec vDUTY, ",", dec wDUTY, 13]
      next
    NEXT
    WereDone:
    Goto WereDone
    Try removing C3, C6 and C8 to start with.
    In reality, I think that my RC filter in Proteus is bad.
    If I watch the raw PWM outputs, it seems perfectly good (with correct phase angles and duty cycles). However, in extreme duty (like 0 or 1023), the PWM "jumps" (like before, I think it's a sim issue, I will try the PIC in the real life with an oscilloscope).
    In other words, my code is working quite well now, thanks for the "**", I didn't know this operator before, until now.
    Like I said in an earlier post, I think it is the dead-time insertion that makes the waveform "jump" at the extreme ends. Do try it with real hardware and let us know how it goes. Just remember that if you low-pass filter the PWM to watch it on a scope might not see any artifacts introduced by the deadtime insertion - if indeed that is what's causing it. So make sure you watch the "raw" PWM signals as well in order to see if it behaves as in the simulator.
    As a simple test, try removing the deadtime insertion from the code and see if it still looks strange in the simulator.
    Yes, of course I've readed your post above. I've modified the code (add +3 to the end of each line), now the PWM signal doesn't "jump" anymore.
    However, if I remove the deadtime or even modify it, the jumpy PWM remains.
    Now signals are better, but sine are not perfect for the highest frequencies, I think that my low-pass filter hasn't good R and C values (1k and 1000nF).
    senertek's Avatar
    senertek Guest
    hi ,
    I have already developped many ac inverters range 0.75 kw to 915 kw..with . I seen this thread ..it s very good..to see picbasic projects in this field....
    Designing one 3 phase ac inverter is not easy project...you must know many kind of points about high voltage igbt , drivers , dcbus topologys ,emc ,emi , multi tasking etc...(it take many years)
    If you want , I can help for your project..
    I can try your codes with my high voltage kits , igbt driver modules ...and inform you ..codes works or not...
    savas
    Quote Originally Posted by senertek View Post
    hi ,
    savas
    Thanks.
    Well, I'm doing studies in electrical engineering, so I've a litte knowledge about this.
    I'm using an intelligent IGBT module from STMicroelectronics, the STGIPS20K60 (datasheet : http://www.st.com/internet/com/TECHN...CD00244265.pdf).
    No drivers needed (they're integrated), just optocouplers.
    Ok, a little update.
    I've tested the program on the real PIC with an oscilloscope. All of the output signals are correct, but the sine cycle is very slow (about 4 seconds to make a complete sine period, so f=1/4=0,25Hz).
    The PWM frequency seems correct (3,245kHz).
    I've defined correctly the configuration fuses (or bits), with "HS oscillator" setting, because I'm using a 40MHz quartz oscillator connected to OSC1/OSC2 pins with 22pF ceramic capacitors.
    The code (note I'm not using the FOR... NEXT loop in this case, like the upper programs, it's a lot faster if I use the FOR... NEXT loop, but I don't know why) :
    'PIC initialization
    DEFINE OSC 40
    DEFINE LCD_EREG PORTD
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    'DT interrupt system include
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
    'Port registers configuration
    PORTB=%0          ' Clear ports
    TRISB=%11000000   ' PWM 0,1,2,3,4,5 outputs
    'PCPWM registers configuration
    DTCON=%110        ' Deadtime (600ns)
    PTCON0=%100       ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
    PTCON1=%10000000  ' PWM time base is ON, counts up, 19.45kHz/4
    PTPERL=%0         ' PWM low-side
    PTPERH=%1         ' PWM high-side
    'PWM registers configuration
    PWMCON0=%1000000  'PWM 0,1,2,3,4,5 set in pair mode
    PWMCON1=%1        'PWM timer sync configuration
    'Interrupt processor
    INT_LIST  macro    ; IntSource, Label, Type, ResetFlag
            INT_Handler   TMR1_INT,  _pwmint,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    'Timer configuration
    T1CON=%10000001            ; Prescaler = 1:8, TMR1ON, 16-bit counter
    @ INT_ENABLE  TMR1_INT     ; Enable Timer 1 interrupts
    'PWM calculation variables
    uduty VAR WORD     'U phase duty
    vduty VAR WORD     'V phase duty
    wduty VAR WORD     'W phase duty
    dutydiv var WORD   'Frequency diviser
    dutymul VAR WORD   'Duty multiplier
    t VAR byte         'Incremental value
    'Variables definition
    dutydiv=0       'Range : 0-65535
    dutymul=65535   'Range : 0-65535 (for exemple, 32767=0.5)
    t=%0            'T initial value
    'Main program loop
    mainlp:
    HIGH PORTA.0
    LOW PORTA.0
    goto mainlp
    'PWM calculation and update interrupt
    pwmint:
        'Frequency diviser
        pauseus dutydiv
        'PWM U, V, W phases calculation
        uduty=(((sin(t)+%01111111)*%100)**dutymul)+%100
        vduty=(((sin(t+%01010101)+%01111111)*%100)**dutymul)+%100
        wduty=(((sin(t+%10101010)+%01111111)*%100)**dutymul)+%100
        'PWM U phase update
        PDC0L=uduty.LOWbyte
        PDC0H=uduty.HIGHByte
        'PWM V phase update
        PDC1L=vduty.LOWbyte
        PDC1H=vduty.HIGHByte
        'PWM W phase update
        PDC2L=wduty.LOWbyte
        PDC2H=wduty.HIGHByte
        'T variable verification and incrementation
        if t<%11111111 then
        t=t+%1
        t=%0
    @ INT_RETURN
    I think it's a TIMER problem (TMR1 is at 32kHz, isn't it?)
    Yes, it's probably a timer problem. You have TMR1 set up to derive its clock from the main oscillator (Fosc/4) so 10Mhz in your case. (Your code comments says you have a prescaler of 8 but you don't - it's 1:1.
    TMR1 is a 16bit timer and generates an interrupt when it overflows from $FFFF to $0000. In your case this means that the interrupt frequency is 10MHz/65536 = 152.6Hz. In other words, the pwmint interrupt service routine is executed 156 times per second.
    If a complete sinus cycle consists of 256 "steps" you should get a frequency of 152.6/256=0.6Hz but you claim 0.25Hz so I'm not sure what's going on exactly.
    If you want to speed up the frequency you must increase the interrupt frequency. You do this by preloading TMR1 in the interrupt service routine so that it doesn't have to count all the way from 0. If you, for example, preset it to 32768 you'll get twice as many interrupts per second as when letting it free run.
