Quote Originally Posted by senertek View Post
hi ,
I have already developped many ac inverters range 0.75 kw to 915 kw..with . I seen this thread ..it s very good..to see picbasic projects in this field....
Designing one 3 phase ac inverter is not easy project...you must know many kind of points about high voltage igbt , drivers , dcbus topologys ,emc ,emi , multi tasking etc...(it take many years)
If you want , I can help for your project..
I can try your codes with my high voltage kits , igbt driver modules ...and inform you ..codes works or not...
savas
Thanks.
Well, I'm doing studies in electrical engineering, so I've a litte knowledge about this.
I'm using an intelligent IGBT module from STMicroelectronics, the STGIPS20K60 (datasheet : http://www.st.com/internet/com/TECHN...CD00244265.pdf).
No drivers needed (they're integrated), just optocouplers.
