6 HPWM signal generation with PIC18F4431
Results 1 to 23 of 23
Threaded View
  1. #4
    Default Re: 6 HPWM signal generation with PIC18F4431
    Okay, I've a little bit modified the Bruce's program.
    It runs well in ISIS Proteus with my defined duty cycles, and all of the 6 PWM outputs works.
    But there is a little problem :
    As you can see, U and W phases are working properly, but not the V phase (the low-side PWM is not inverted like the others).
    Here's my modified code :
    DEFINE LOADER_USED 1
    DEFINE OSC 20
        ' At 20MHz, to figure a PWM frequency of 19.455kHz
        ' TPWM = time period of PWM frequency
        ' PTPER = 12-bit period register PTPERL and PTPERH
        ' PTMRPS = PWM time base prescaler
        '        (PTPER+1)*PTMRPS  257
        ' TPWM = ----------------  =  ------------ = 0.0000514
        '             Fosc/4            5000000
        ' Frequency = 1/TPWM = 1/0.0000514 = 19.455kHz
        ' PWM resolution (bits resolution for duty cycle)
        '              log(20MHz/19.455kHz)    3.01
        ' Resolution = ------------------ = ----------- = 10 bits
        '                    .301              .301
        ' so we'll need a word sized var for Duty
    uduty VAR WORD
    vduty VAR WORD
    wduty VAR WORD
        PORTB = 0               ' clear port latch
        TRISB = %11000000       ' PWM0,1,2,3,4,5 outputs
        TRISC = 2         ' RC1 = FLTA input (ground RC1 to halt PWM)
                                ' RC1 should be pulled high for normal PWM operation
                                ' when fault A is enabled.
        ' PCPWM init
        DTCON = %00000101       ' ~500nS dead-time (for complementary outputs only)
        PTCON0 = %00000100      ' 1:1 postscale, Fosc/4 1:1 prescale, free running mode
                                ' PTCON0 = %00000100 would give 19.45kHz/4
        PTPERL = 0              '
        PTPERH = 1              ' PTPER = $0100 or 256d for ~19.45kHz
        ' PWM4,5 independent, PWM0,1,2,3 complementary
        PWMCON0 = %01010100     ' PWM[5:0] outputs enabled
        PWMCON1 = 1             ' updates enabled, overrides sync w/timebase
        PTCON1 = %10000000      ' PWM time base is ON, counts up
        FLTCONFIG = %00000011   ' enable fault A, cycle-by-cycle mode
    'Phases duty test
    uduty = 800              ' ~50%
    vduty = 500
    wduty = 300
    pwmlp: ' PWM update loop
    'PWM U phase
    PDC0L = uduty.LowByte
    PDC0H = uduty.HighByte
    'PWM V phase
    PDC1L = vduty.LowByte
    PDC1H = vduty.HighByte
    'PWM W phase
    PDC2L = wduty.LowByte
    PDC2H = wduty.HighByte
    goto pwmlp
    Thanks in advance for any advice.
