"Honey, my PIC ADC pin sagged my peak detector voltage!"
Results 1 to 10 of 10
    Mar 2009
    Default Re: "Honey, my PIC ADC pin sagged my peak detector voltage!"
    Hank,
    Weak Pull-ups are disabled at power-up / Reset.
    They are turned on by clearing WPUEN (OPTION_REG.7).
    All of the WPUx registers are enabled at power-up, so when you clear the WPUEN bit, they all come on unless you specifically disable individual pins WPUC.x.
    Does your code change OPTION_REG?
    Hey Darrel,
    this is the point in the proceeedings where I should lie profusely, but nope....
    "It's a fair cop guv"
    Yes, I do use WUPs on PORT B, so yes I have...
    OPTION_REG.7 = 0
    ....which of course, then means all ports are enabled & I need to disable by port.
    My excuse is that my code is a heavy cut/paste from a former program, so I didn't enter every single line manually......but, that's lame so I offically declare myself a pleb.
    Great spot....... & thanks for chiming in to correct.
