More Pic basic pro maths help.
Results 1 to 6 of 6
    timmers's Avatar
    timmers Guest
    Default Re: More Pic basic pro maths help.
    So assuming :-
    Amps ADC value
    -100 0000
    0 0511
    +100 1023
    Equates to 201 amp values against 1024 a2d values gives us 1024/201 =5.094 a2d's per amp. By multiplying up we lose less in the division.
    If using LONG variables you can get even more accuracy.
    ADC_VALUE VAR WORD
    AMPS VAR BYTE
    AMPS_SIGN VAR BYTE
    AMPS_CHAR VAR BYTE
    ADCIN x,ADC_VALUE 'collect a2d
    ADC_VALUE = ADC_VALUE *64 'multiply up by 64 (assuming a WORD variable)
    AMPS = ADC_VALUE / 326 'divide down by 64 * 5.094
    IF AMPS <100 THEN 'negative amps
    AMPS_SIGN ="-"
    AMPS_CHAR =100 -AMPS
    ELSE 'positive amps
    AMPS_SIGN ="+"
    AMPS_CHAR =AMPS -100
    LCDOUT $FE,128,AMPS_SIGN, DEC3 AMPS
    Ok.
    Timmers.
    Thanks Timmers that's a big improvement.
    I'm using a pic 16F886 so can't use long variables sadly.
    Anyone else any other ideas?
    Not tested but how about:
    ADC_VALUE VAR WORD
    AMPS VAR WORD
    i VAR BYTE
    AMPS = 0
    For i = 0 to 3              ' Sample 4 times
      ADCIN 0,ADC_VALUE         ' Get actual value
      AMPS = AMPS + ADC_VALUE   ' Accumulate
    NEXT
    AMPS = AMPS >> 1            ' Divide by 2, AMPS is now 0-2048
    AMPS = AMPS ** 64000        ' Multiply by ~0.97656, AMPS is now 0-2000
    AMPS = AMPS - 1000          ' AMPS is now +/-1000, change to AMPS=1000-AMPS to invert.
    LCDOUT $FE,$1, "Current: ", SDEC AMPS/10, ".", DEC ABS(AMPS // 10)
    Clever Henrik. I actually do capture ten samples and average them to get a reliable figure. But your maths after that is interesting. Wish i understood all the funny symbols >> etc
    Thanks i might try that.
    The >> is the shift right operator, it shifts the word, in this case, one bit to the right which effectively is the same as dividing by 2. It's really not needed as you might as well change 64000 to 32000 to get the same end result (a value ranging from 0-2000)
    In your case, with ten accumulating samples you could remove the shift operation and do Amps = Amps ** 12800 to get value ranging from 0-2000.
    The ** operator multiplies by the value you specify and then returns the top 16bits of the intermediate 32bit result (you don't need LONGS for this). In effect this is the same as first multiplying by your value and then dividing by 65536. 12800/65536=0.1953 and 10240*0.1953=2000.
    Good luck!
