Real time clock
Results 1 to 9 of 9
Thread: Real time clock
    Mar 2008
    Default Real time clock
    I am using a PIC18F2450 and need real time clock to schedule events, is this possible in the PIC? if not, is there a 28pin PIC with PIC18F2450 specs and real time clock? Is there an external chip that I could interface with?
    Aug 2008
    Portugal
    Default Re: Real time clock
    Quote Originally Posted by PlantBob View Post
    Hi;
    There are various external RTC Chips. One that is very easy to interface and there are several exemples in this forum is the DS1307. There are some PICs with RTC, go to Microchip site and use the chip selector.
    Thanks and Regards;
    Gadelhas
    Mar 2008
    Ok, I decided to order a PIC18F24J50 that has an internal RTC, Do you know I set/read the clock?
    Here is a great example from Bruce:
    http://www.picbasic.co.uk/forum/cont...le-pin-options
    Mar 2008
    I saw that sample but I am not sure why I would need to remap pins? I not sure if that is there for something else or just for the RTC. Also, do I need external Oscillator and Capacitors for the internal RTC on the 18F24J50?
    No, you don't need to remap the pins. It is a dual example. He show both " so I'm posting a simple example here showing how to use the RTCC, and how to assign PWM to several pins."
    For you, you can just look at the RTC part.
    From the data sheet under RTCC
    • Requirements: external 32.768 kHz clock crystal
      ' Connect a 32.768 kHz watch crystal between pins 11 & 12 T1CKI & T1OSI
      ' with caps to match your crystal load capacitance.
      ' 11        12
      '  |  xtal  |
      ' _|_      _|_
      ' ___      ___  2 x 12pF caps
      ' gnd      gnd
    Mar 2008
    Any idea where I can get the 12.5pf capacitors? I have checked all my online suppliers and can't find them.
    The 12 pF capacitors should work fine.
    And if you want the ultimum accuracy, then replace one capacitor with a trimmer (say 6-15pF) to calibrate it.
