I'm used same code on PIC18LF13K50, now i just copy/paste same code for PIC18LF2550
But 1 byte is always zero.
I tried like this
But apn_name[0] always has the value 0.Code:APN_Name var byte[20] APN_Pass var byte[20] APN_User var byte[20] serin2 PC_RX,Baud_Rate,500,PC_Data,[wait("DATA:"),day, month, yr, hour, minut, sek,str dat\4,_ str sms_no\20,_ str apn_name\20,str apn_user\20, str apn_pass\20,_.....
Then i tried this
Same result.Code:serin2 PC_RX,Baud_Rate,500,PC_Data,[.... apn_name[0],apn_name[1],apn_name[2],apn_name[3],apn_name[4],apn_name[5],apn_name[6],apn_name[7],apn_name[8],apn_name[9],apn_name[10],apn_name[11],apn_name[12],apn_name[13],apn_name[14],apn_name[15],apn_name[16],apn_name[17],apn_name[18],apn_name[19],_ str apn_user\20, str apn_pass\20,_...]
Then i tried this
Now it was expected that apn_name[1] is 0, but its value is now fine,Code:serin2 PC_RX,Baud_Rate,500,PC_Data,[.... apn_name[1],apn_name[2],apn_name[3],apn_name[4],apn_name[5],apn_name[6],apn_name[7],apn_name[8],apn_name[9],apn_name[10],apn_name[11],apn_name[12],apn_name[13],apn_name[14],apn_name[15],apn_name[16],apn_name[17],apn_name[18],apn_name[19],apn_name[0],_ str apn_user\20, str apn_pass\20,_...
but apn_name[0] is 0
I tried to move position of apn_name[0], and its always 0
I tried to change name of variable apn_name into apn,apn1,apn_1, but always same...
And all data before and after apn_name[0] were received correctly.
Does anybody have idea what is going on![]()
