Not sure whats wrong here
Results 1 to 4 of 4
    Aug 2010
    Maryland, USA
    Default Not sure whats wrong here
    This is being with 2.6A for 16F1947
    here is the error message:
    ERROR: Macro NAND?TTL not found in macro file.Halting build on first failure as requested.
    BUILD FAILED: Sun Feb 06 12:43:14 2011
    and the offending code:
    IF (LSH1 &/ HSP1) THEN LIMITHIT
    I tried it with and without the (), still no joy.
    LSH1 and HSP1 are both bits, so I thought this should work?
    Any insight would be great here, thanks!!
    -Bert
    Default Re: Not sure whats wrong here
    Looks like a compiler parser "feature"
    try
    IF (LSH1 &/ HSP1)=1 THEN LIMITHIT
    And then
    IF (LSH1 &/ HSP1) THEN GOTO LIMITHIT
    BTW, you should use "Logical Operator" not "Bitwise operator", unless I miss something.
    IF (LSH1 ANDNOT HSP1) THEN LIMITHIT
    &/ is a bitwise operator.
    ANDNOT is a logical operator ...
    IF LSH1 ANDNOT HSP1 THEN LIMITHIT
    Aug 2010
    Maryland, USA
    Thank you both! Turns out I finally get the difference now. I have read it in the manual and somehow kept not being able to make the distinction.
    As a side not, I really needed ORnot instead of ANDnot. but thats a different story.
    -Bert
