speedometer without timer1
Results 1 to 9 of 9
    Talking Re: speedometer without timer1
    "Crystal ball help me... crystal ball... tell me which PIC the OP's using... maybe he could use Timer 0 for it's counting purpose?
    Crystal ball tell me more about the OP's requirement...."
    Default Re: speedometer without timer1
    LOL Mister E
    Pic is 16F88
    I think timer 0 is only 8 bit so can't count high enough?
    It really depend what you need to do with the incoming pulse. Timer0 also have Prescaller/divider, you can play with the acquisition time, and maybe use the overflow interrupt (if any for TMR0).
    We don't know the purpose of your 2 PWMs... hard to suggest things.
    The two pwms have to continue unaffected in the background.
    What about the RC idea and using the adc to acquire the voltage?
    Sure less flexible & accurate than the Timer idea.
    Look @ the classic LM2917... Frequency to Voltage converter. That must mean something
    Sep 2005
    Campbell, CA
    You can use a timer interrupt. You can use TMR0 or just "piggyback" on Darrel's TMR1 interrupt in the SSPWM routine.
    The only caveat is that the period of that interrupt must be shorter than the narrowest pulse (either high or low) that your speedometer sensor puts out.
    I have written (and posted) a routine that would do what you want. Mine is written in asm, but could be written in PBP as well.
    Below is a section. It measures the speed of 9 fans by watching the tachometers.
    A couple of things to note -
    It must be written as an ISR.
    The interrupt time is determined by PRELOADH and PRELOADL.
    The routine runs for an exact number of interrupts before stopping (FanClock is the counter) 1000 is the number here.
    So if you interrupt at 1mSec intervals, this routine will run for 1 second before being restarted in the main loop.
    To use:
    Set your interrupt rate.
    Determine how many counts you need to get the accuracy you want (which determines
    how long you need to count and therefore, the maximum update rate of your speedometer).
    If you get 1 cycle (1 high period and one low period) per foot, and you have a 50% duty cycle, then you will get 88 cycles per second with a high period of 5.6 mSec and a low period of 5.6 mSec. To account for jitter, your interrupt period would have to be 5 mSec or less. You would have 166 transitions (low->high + high -> low) in one second. If you set FanCounter to time out in .3614 seconds (say 100 counts with a 3.614 mSec update rate), the count would be in exact mph with a .3614 second update rate. Longer counting intervals and faster interrupts gives more accuracy and less jitter.
    You need clear TPE before you start.
    Check TPE in your main loop. If it is set, the routine has completed. Transfer the contents of the FanxCounters to another set of variables (call them FanYcounters, clear all the FanXcounters, Clear FanClock and Clear TPE. Now your main loop can read FanYcounters and display the mph, or RPM, or whatever.
    You don't have to stop TMR0 on most chips to reload it. You do have to stop most of the other timers before reloading. Check your datasheet.
    The routine runs for an exact number of interrupts before stopping. You need clear TPE before you start.
    Asm
    ReadTachs
             movff    PreloadH,TMR0H  ; Preload depends on clk speed
             movff    PreloadL,TMR0L
             infsnz  MasterClock
             incf    MasterClock + 1
             btfsc   TPE,0
             bra     DoneForNow
    ;CheckFans
             infsnz  FanClock
             incf    FanClock + 1
             movlw   0x03 - 1          ; Real value is 1000 = 0x3E8, but must have one less
             cpfsgt  FanClock + 1      ; to compare with greater than
             bra     FanRoutine
             movlw   0xE8 - 1          ; Likewise, subtract one here, too.
             cpfsgt  FanClock
             bra     FanRoutine
             bsf     TPE,0
             clrf    FanClock
             clrf    FanClock + 1
             bra     DoneForNow
    FanRoutine
             movf    PORTB,0,0
             movwf   Temp,0            ; Save VAR so can't change between compare and save
             xorwf   OldPortB,0,0
             movwf   changedB,0
             movff   Temp,OldPortB
             movf    PORTC,0,0
             movwf   Temp,0
             xorwf   OldPortC,0,0
             movwf   changedC,0
             movff   Temp,OldPortC
             movf    PORTD,0,0
             movwf   Temp,0
             xorwf   OldPortD,0,0
             movwf   changedD,0
             movff   Temp,OldPortD
    Fan1
             btfss   changedB,0
             bra     Fan2
             infsnz  Fan1Counter
             incf    Fan1Counter+1
    Fan2
             btfss   changedB,1
             bra     Fan3
             infsnz  Fan2Counter
             incf    Fan2Counter+1
    Fan3
             btfss   changedB,2
             bra     Fan4
             infsnz  Fan3Counter
             incf    Fan3Counter+1
    Fan4
             btfss   changedB,3
             bra     Fan5
             infsnz  Fan4Counter
             incf    Fan4Counter+1
    Fan5
             btfss   changedB,4
             bra     Fan6
             infsnz  Fan5Counter
             incf    Fan5Counter+1
    Fan6
             btfss   changedB,5
             bra     Fan7
             infsnz  Fan6Counter
             incf    Fan6Counter+1
    Fan7
             btfss   changedC,0
             bra     Fan8
             infsnz  Fan7Counter
             incf    Fan7Counter+1
    Fan8
             btfss   changedD,5
             bra     Fan9
             infsnz  Fan8Counter
             incf    Fan8Counter+1
    Fan9
             btfss   changedD,4
             bra     DoneForNow
             infsnz  Fan9Counter
             incf    Fan9Counter+1
    DoneForNow
             bcf     INTCON,2   ; Clear the TIMER0 interrupt flag
            INT_RETURN	 		; WAS RETFIE FAST      Return from the interrupt
    Charles Linquist
