HID USB Multimedia Keypad
Results 1 to 32 of 32
    Feb 2011
    Default Re: HID USB Multimedia Keypad
    Ok I am seeing some wierd things in the new USB Descriptor file for PBP 2.60. Is there a filesize limit for the descriptors now?
    I have not heard of any changes . Not sure why there would be.
    Which file are you looking at?
    Feb 2011
    I converted my project to the new format and everything was ok so I went ahead and added the section for the Endpoint 1 In. Once I added it I started getting 'Block overflow for ENDASM'.
    I went over and over the ASM code in the descriptor and nothing was wrong. I removed an equal amount of comment lines and it compiled ok. I continued to do the same thing but ran out of comment lines I could remove, My full USB Descriptor file is quite big and I can't even finish getting all of the first endpoint code in before getting the error.
    I am afraid you are beyond me. I have not written my own descriptor file Sorry.
    Feb 2011
    Wierd thing is it works fine if i use the old method but still compile for PBP 2.60, its just the new method of putting the descriptor in a BAS file as an include that does not work.... I guess I will just stick to the old method for now.
    Must but a problem with PBP itself, I hope they fix it.
    P.S.: Just wanted to let you know that the interrupt method you gave me (the instant one) works wonders, I moved the button press code to interrup also and works perfectly, thanks so much
    There is a limit to the number of characters in a single ASM block (includes comments and spaces/tabs).
    You can just start a new block when you reach the limit ...
    Feb 2011
    All I can say is WOW, thanks so much, you are an absolute genius
    I searched and search the new PBP 2.60 manual and did not see any mention of that and would have never guessed that was the cause.
    Again thanks. Oh and great job on your Interrupt routines, works wonders
