Great!!
Your base code should not really change, just the supporting files. So what I do when upgrading an old project like this is start a new directory with the old base code and all of the new supporting files if I need the features from the new PBP. Otherwise I just leave things as they are and use the version of PBP that was originally used for the project. You can have more than one version of PBP installed, just pick the one you want at compile time.I noticed they really changed the USB examples in the new PBP, is it hard to convert an exsisting project to the new format or is it even worth doing.
