Would it be difficult to do the USB Service with an interrupt routine instead of in the main loop?
ISR is the way to go. Here is a project using DT's Instants.
http://www.picbasic.co.uk/forum/cont...USB-SD-LOGGING
Darrel gave us another USB service routine also, but it seems to work best as a stand alone ISR. That is why I like using the Instant approach.
But you can take a look at the other here.
http://www.picbasic.co.uk/forum/show...8306#post78306
Thanks again for the help.
I put the code you sugested in but I keep getting an error saying Syntax Error for
UIE = $7F 'ENABLE USB INTERRUPTS
I am using Picbasic Pro 2.47
Can you give a little more info.. Are you trying the instant solution or the other?
Go ahead and post your code and config setup.
Ok I updated to PBP 2.60 (just found the CD) and it compiles ok now but if I enable the innterrupt routines it won't detect the device.
I am using a custom HID Bootloader (Modified the Microchip one since it won't compile using the free tools)
I am also using an external 48MHz Oscilator since I have hundreds.
Ok I just had some of that code you gave me in wrong place, seems to be working fine now.
I noticed they really changed the USB examples in the new PBP, is it hard to convert an exsisting project to the new format or is it even worth doing.
