PCf8573 RTC
Results 1 to 2 of 2
Thread: PCf8573 RTC
    Feb 2011
    Default PCf8573 RTC
    Hello.
    I have two IC's named PCF8573. I have read the datasheet and it's similar to PCF8583 and not. Can someone post an example of how can I read and write this rtc. Or maybe someone can translate the datasheet (control, adress). Thank you!
    Feb 2011
    Is it okay if I write these commands? (My logic is correct?)
    msb lsb
    i2cread SDA,SCl,% 1 101000 1 ,0,[H] ( BIT4=0, B2=0, B1=0, B0=0)
    i2cread SDA,Scl,%11010001,1,[M] ( BIT4=0, B2=0, B1=0, B0=1)
    and so on?
    I don't know what this bits do: MODE-POINTER-word, CONTROL-nibble (bits 8, 7, 6 and 5)
