try this
' I/O definition
TRISB = %10000001   ' Set PORTB (0)INPUT (1-5)OUTPUTS
' Variable Definition
Switch              VAR PORTB.0
Red                 VAR PORTB.1
Green               VAR PORTB.2
Blue                VAR PORTB.3
PushHowManyTimes    VAR Byte
PWMVariable         VAR Byte	' PWM Variable 1-9
PWMVariableTimeOut  VAR Byte	' 5 second Timeout (100 loops of 50mS)
storedloop          VAR Byte
onled               VAR Byte
DelayVar VAR WORD
' register and interrupt definition
CMCON = 7          ' Disable analog comparator on PORTA... not needed as now
OPTION_REG=0       ' enable pull-up resistor on PORTb
                   ' Interrupt on falling edge of RB0
INTCON = %10010000 ' Enable RB0 interrupt
On Interrupt Goto ProcedureSwitcher
' Variable initialisation
'PORTB = 0             ' Reset all outputs on PORTB
PushHowManyTimes = 0
DelayVar = 0
'Main Procedure
MainProcedure:
      Select Case PushHowManyTimes
             case 1
                  Gosub resetleds
                  PWMVariable = 1
                  PWM BLue,1,100
             Case 2
                  Gosub resetleds
                  PWMVariable = 2
                  PWM blue,25,100
             Case 3
                  Gosub resetleds
                  PWMVariable = 3
                  PWM blue,255,100
             Case 4
                  Gosub resetleds
                  PWMVariable = 4
                  PWM green,1,100
             Case 5
                  Gosub resetleds
                  PWMVariable = 5
                  PWM green,25,100
             Case 6
                  Gosub resetleds
                  PWMVariable = 6
                  PWM green,255,100
             Case 7
                  Gosub resetleds
                  PWMVariable = 7
                  PWM red,1,100
             Case 8
                  Gosub resetleds
                  PWMVariable = 8
                  PWM red,25,100
             Case 9
                  Gosub resetleds
                  PWMVariable = 9
                  PWM red,255,100
             End Select
pauseus 100
delayvar=delayvar + 1
if delayvar = 50000 then
   delayvar=0
   PushHowManyTimes=PushHowManytimes+1
   If PushHowManyTimes=10 then PushHowManytimes=1
Goto Mainprocedure
ResetLEDs:
    Low PortB.1                             ' reset output to PORTB
    Low PortB.2
    Low PortB.3
    Low PortB.4
    Low PortB.5
' Interrupt handler stuff here
Disable                                     ' Disable interrupts in handler
ProcedureSwitcher:
    PushHowManytimes = PushHowManytimes + 1     ' Changing task
    If PushHowManytimes = 10 Then PushHowManytimes=1
Here:
    While SWITCH = 0                        ' waiting until
    wend                                    ' push-button is release
    pause 100                               ' debounce time
    If switch = 0 then here
    INTCON.1=0                              ' reset RB0 interrupt flag
    DelayVar= 0
Resume                                      ' Return to main program
Enable                                      ' Enable interrupts after
                                            ' handler
