DT interups - out of ram 16F1824
Results 1 to 5 of 5
    Default DT interups - out of ram 16F1824
    ERROR: Variable wsave3 position request 416 beyond RAM_END 367.
    oky, this is the second chip i've picked to do a job after the first also reported an out of ram error...
    I removed my code and i still get the same error... so, DT ints is on it's own...
    Can someone (DT?) take a look at the ASM below and tell me if if something looks amiss. I've scanned it myself but can't see anything wrong...
    thanks
    ; PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc. All Rights Reserved.
    _USED			EQU	1
    	INCLUDE	"C:\PBP2.60B\16F1824.INC"
    ; Define statements.
    ; C:\PBP2.60B\16F1824.BAS  	00017	DEFINE  CODE_SIZE 4
    #define		CODE_SIZE		 4
    ; C:\PBP2.60B\16F1824.BAS  	00018	DEFINE	CCP1_REG PORTC
    #define		CCP1_REG		 PORTC
    ; C:\PBP2.60B\16F1824.BAS  	00019	DEFINE	CCP1_BIT 5
    #define		CCP1_BIT		 5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00015	Define  OSC				32						' Set clock speed
    #define		OSC						32
    ; C:\PBP2.60B\DT_INTS-14.BAS	00012	DEFINE  INTHAND  INT_ENTRY
    #define		INTHAND		  INT_ENTRY
    ; C:\PBP2.60B\REENTERPBP.BAS	00012	DEFINE   ReEnterUsed  1
    #define		ReEnterUsed		  1
    RAM_START       		EQU	00020h
    RAM_END         		EQU	0016Fh
    RAM_BANKS       		EQU	00003h
    BANK0_START     		EQU	00020h
    BANK0_END       		EQU	0007Fh
    BANK1_START     		EQU	000A0h
    BANK1_END       		EQU	000EFh
    BANK2_START     		EQU	00120h
    BANK2_END       		EQU	0016Fh
    EEPROM_START    		EQU	0F000h
    EEPROM_END      		EQU	0F0FFh
    ; C:\PBP2.60B\DT_INTS-14.BAS	00014	A00020	wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    wsave           		EQU	RAM_START + 000h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00012	A00021	R0      VAR     WORD BANK0 SYSTEM       ' System Register
    R0              		EQU	RAM_START + 001h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00013	A00023	R1      VAR     WORD BANK0 SYSTEM       ' System Register
    R1              		EQU	RAM_START + 003h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00014	A00025	R2      VAR     WORD BANK0 SYSTEM       ' System Register
    R2              		EQU	RAM_START + 005h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00015	A00027	R3      VAR     WORD BANK0 SYSTEM       ' System Register
    R3              		EQU	RAM_START + 007h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00016	A00029	R4      VAR     WORD BANK0 SYSTEM       ' System Register
    R4              		EQU	RAM_START + 009h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00017	A0002B	R5      VAR     WORD BANK0 SYSTEM       ' System Register
    R5              		EQU	RAM_START + 00Bh
    ; C:\PBP2.60B\PBPPI14E.RAM 	00018	A0002D	R6      VAR     WORD BANK0 SYSTEM       ' System Register
    R6              		EQU	RAM_START + 00Dh
    ; C:\PBP2.60B\PBPPI14E.RAM 	00019	A0002F	R7      VAR     WORD BANK0 SYSTEM       ' System Register
    R7              		EQU	RAM_START + 00Fh
    ; C:\PBP2.60B\PBPPI14E.RAM 	00020	A00031	R8      VAR     WORD BANK0 SYSTEM       ' System Register
    R8              		EQU	RAM_START + 011h
    ; C:\PBP2.60B\DT_INTS-14.BAS	00029	A00033	RetAddr     VAR WORD    BANK0
    _RetAddr         		EQU	RAM_START + 013h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00028	A00035	FLAGS   VAR     BYTE BANK0 SYSTEM       ' Static flags
    FLAGS           		EQU	RAM_START + 015h
    ; C:\PBP2.60B\DT_INTS-14.BAS	00028	A00036	fsave       var byte    BANK0   SYSTEM      ' location for FSR register
    fsave           		EQU	RAM_START + 016h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00027	A00037	GOP     VAR     BYTE BANK0 SYSTEM       ' Gen Op Parameter
    GOP             		EQU	RAM_START + 017h
    ; C:\PBP2.60B\DT_INTS-14.BAS	00027	A00038	psave       var byte    BANK0   SYSTEM      ' location for PCLATH register
    psave           		EQU	RAM_START + 018h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00023	A00039	RM1     VAR     BYTE BANK0 SYSTEM       ' Pin 1 Mask
    RM1             		EQU	RAM_START + 019h
    ; C:\PBP2.60B\PBPPI14E.RAM 	00026	A0003A	RM2     VAR     BYTE BANK0 SYSTEM       ' Pin 2 Mask
    RM2             		EQU	RAM_START + 01Ah
    ; C:\PBP2.60B\PBPPI14E.RAM 	00021	A0003B	RR1     VAR     BYTE BANK0 SYSTEM       ' Pin 1 Register
    RR1             		EQU	RAM_START + 01Bh
    ; C:\PBP2.60B\PBPPI14E.RAM 	00024	A0003C	RR2     VAR     BYTE BANK0 SYSTEM       ' Pin 2 Register
    RR2             		EQU	RAM_START + 01Ch
    ; C:\PBP2.60B\PBPPI14E.RAM 	00022	A0003D	RS1     VAR     BYTE BANK0 SYSTEM       ' Pin 1 Bank
    RS1             		EQU	RAM_START + 01Dh
    ; C:\PBP2.60B\PBPPI14E.RAM 	00025	A0003E	RS2     VAR     BYTE BANK0 SYSTEM       ' Pin 2 Bank
    RS2             		EQU	RAM_START + 01Eh
    ; C:\PBP2.60B\DT_INTS-14.BAS	00026	A0003F	ssave       var byte    BANK0   SYSTEM      ' location for STATUS register
    ssave           		EQU	RAM_START + 01Fh
    ; C:\PBP2.60B\REENTERPBP.BAS	00020	A00040	    R0_Save     VAR WORD
    _R0_Save         		EQU	RAM_START + 020h
    ; C:\PBP2.60B\REENTERPBP.BAS	00021	A00042	    R1_Save     VAR WORD
    _R1_Save         		EQU	RAM_START + 022h
    ; C:\PBP2.60B\REENTERPBP.BAS	00022	A00044	    R2_Save     VAR WORD
    _R2_Save         		EQU	RAM_START + 024h
    ; C:\PBP2.60B\REENTERPBP.BAS	00023	A00046	    R3_Save     VAR WORD
    _R3_Save         		EQU	RAM_START + 026h
    ; C:\PBP2.60B\REENTERPBP.BAS	00024	A00048	    R4_Save     VAR WORD
    _R4_Save         		EQU	RAM_START + 028h
    ; C:\PBP2.60B\REENTERPBP.BAS	00025	A0004A	    R5_Save     VAR WORD
    _R5_Save         		EQU	RAM_START + 02Ah
    ; C:\PBP2.60B\REENTERPBP.BAS	00026	A0004C	    R6_Save     VAR WORD
    _R6_Save         		EQU	RAM_START + 02Ch
    ; C:\PBP2.60B\REENTERPBP.BAS	00027	A0004E	    R7_Save     VAR WORD
    _R7_Save         		EQU	RAM_START + 02Eh
    ; C:\PBP2.60B\REENTERPBP.BAS	00028	A00050	    R8_Save     VAR WORD
    _R8_Save         		EQU	RAM_START + 030h
    ; C:\PBP2.60B\REENTERPBP.BAS	00037	A00052	    T1_Save     VAR WORD
    _T1_Save         		EQU	RAM_START + 032h
    ; C:\PBP2.60B\REENTERPBP.BAS	00038	A00054	    T2_Save     VAR WORD
    _T2_Save         		EQU	RAM_START + 034h
    ; C:\PBP2.60B\REENTERPBP.BAS	00039	A00056	    T3_Save     VAR WORD
    _T3_Save         		EQU	RAM_START + 036h
    ; C:\PBP2.60B\REENTERPBP.BAS	00040	A00058	    T4_Save     VAR WORD
    _T4_Save         		EQU	RAM_START + 038h
    ; C:\PBP2.60B\REENTERPBP.BAS	00029	A0005A	    Flags_Save  VAR BYTE
    _Flags_Save      		EQU	RAM_START + 03Ah
    ; C:\PBP2.60B\REENTERPBP.BAS	00030	A0005B	    GOP_Save    VAR BYTE
    _GOP_Save        		EQU	RAM_START + 03Bh
    ; D:\FED\CLC\LIGHTD~2.PBP  	00001	A0005C	'****************************************************************
    PB01            		EQU	RAM_START + 03Ch
    ; C:\PBP2.60B\REENTERPBP.BAS	00031	A0005D	    RM1_Save    VAR BYTE
    _RM1_Save        		EQU	RAM_START + 03Dh
    ; C:\PBP2.60B\REENTERPBP.BAS	00032	A0005E	    RM2_Save    VAR BYTE
    _RM2_Save        		EQU	RAM_START + 03Eh
    ; C:\PBP2.60B\REENTERPBP.BAS	00033	A0005F	    RR1_Save    VAR BYTE
    _RR1_Save        		EQU	RAM_START + 03Fh
    ; C:\PBP2.60B\REENTERPBP.BAS	00034	A00060	    RR2_Save    VAR BYTE
    _RR2_Save        		EQU	RAM_START + 040h
    ; C:\PBP2.60B\REENTERPBP.BAS	00035	A00061	    RS1_Save    VAR BYTE
    _RS1_Save        		EQU	RAM_START + 041h
    ; C:\PBP2.60B\REENTERPBP.BAS	00036	A00062	    RS2_Save    VAR BYTE
    _RS2_Save        		EQU	RAM_START + 042h
    ; C:\PBP2.60B\DT_INTS-14.BAS	00021	A000A0	wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave1          		EQU	RAM_START + 080h
    ; C:\PBP2.60B\DT_INTS-14.BAS	00022	A00120	wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    wsave2          		EQU	RAM_START + 00100h
    ; C:\PBP2.60B\16F1824.BAS  	00023	PORTL   VAR     PORTA
    _PORTL           		EQU	 PORTA
    ; C:\PBP2.60B\16F1824.BAS  	00024	PORTH   VAR     PORTC
    _PORTH           		EQU	 PORTC
    ; C:\PBP2.60B\16F1824.BAS  	00025	TRISL   VAR     TRISA
    _TRISL           		EQU	 TRISA
    ; C:\PBP2.60B\16F1824.BAS  	00026	TRISH   VAR     TRISC
    _TRISH           		EQU	 TRISC
    #define _Serviced        	 PB01, 000h
    #define _VarsSaved       	 PB01, 001h
    #define _OSCCON??7       	 OSCCON, 007h
    #define _OSCCON??6       	 OSCCON, 006h
    #define _OSCCON??5       	 OSCCON, 005h
    #define _OSCCON??4       	 OSCCON, 004h
    #define _OSCCON??3       	 OSCCON, 003h
    #define _OSCCON??1       	 OSCCON, 001h
    #define _OSCCON??0       	 OSCCON, 000h
    #define _FVRCON??7       	 FVRCON, 007h
    #define _FVRCON??5       	 FVRCON, 005h
    #define _FVRCON??4       	 FVRCON, 004h
    #define _FVRCON??3       	 FVRCON, 003h
    #define _FVRCON??2       	 FVRCON, 002h
    #define _FVRCON??1       	 FVRCON, 001h
    #define _FVRCON??0       	 FVRCON, 000h
    #define _ADCON1??6       	 ADCON1, 006h
    #define _ADCON1??5       	 ADCON1, 005h
    #define _ADCON1??4       	 ADCON1, 004h
    #define _ADCON1??2       	 ADCON1, 002h
    #define _ADCON1??1       	 ADCON1, 001h
    #define _ADCON1??0       	 ADCON1, 000h
    #define _FVRCON??6       	 FVRCON, 006h
    #define _TRISC??5        	 TRISC, 005h
    #define _TRISC??3        	 TRISC, 003h
    #define _TRISA??2        	 TRISA, 002h
    #define _TRISC??1        	 TRISC, 001h
    #define _APFCON1??0      	 APFCON1, 000h
    #define _CCP1CON??7      	 CCP1CON, 007h
    #define _CCP1CON??6      	 CCP1CON, 006h
    #define _CCP1CON??3      	 CCP1CON, 003h
    #define _CCP1CON??2      	 CCP1CON, 002h
    #define _CCP1CON??1      	 CCP1CON, 001h
    #define _CCP1CON??0      	 CCP1CON, 000h
    #define _CCP2CON??7      	 CCP2CON, 007h
    #define _CCP2CON??6      	 CCP2CON, 006h
    #define _CCP2CON??3      	 CCP2CON, 003h
    #define _CCP2CON??2      	 CCP2CON, 002h
    #define _CCP2CON??1      	 CCP2CON, 001h
    #define _CCP2CON??0      	 CCP2CON, 000h
    #define _CCP3CON??7      	 CCP3CON, 007h
    #define _CCP3CON??6      	 CCP3CON, 006h
    #define _CCP3CON??3      	 CCP3CON, 003h
    #define _CCP3CON??2      	 CCP3CON, 002h
    #define _CCP3CON??1      	 CCP3CON, 001h
    #define _CCP3CON??0      	 CCP3CON, 000h
    #define _CCP4CON??7      	 CCP4CON, 007h
    #define _CCP4CON??6      	 CCP4CON, 006h
    #define _CCP4CON??3      	 CCP4CON, 003h
    #define _CCP4CON??2      	 CCP4CON, 002h
    #define _CCP4CON??1      	 CCP4CON, 001h
    #define _CCP4CON??0      	 CCP4CON, 000h
    #define _CCPTMRS0??7     	 CCPTMRS0, 007h
    #define _CCPTMRS0??6     	 CCPTMRS0, 006h
    #define _CCPTMRS0??5     	 CCPTMRS0, 005h
    #define _CCPTMRS0??4     	 CCPTMRS0, 004h
    #define _CCPTMRS0??3     	 CCPTMRS0, 003h
    #define _CCPTMRS0??2     	 CCPTMRS0, 002h
    #define _CCPTMRS0??1     	 CCPTMRS0, 001h
    #define _CCPTMRS0??0     	 CCPTMRS0, 000h
    #define _T6CON??6        	 T6CON, 006h
    #define _T6CON??5        	 T6CON, 005h
    #define _T6CON??4        	 T6CON, 004h
    #define _T6CON??3        	 T6CON, 003h
    #define _T6CON??1        	 T6CON, 001h
    #define _T6CON??0        	 T6CON, 000h
    #define _T6CON??2        	 T6CON, 002h
    #define _T4CON??6        	 T4CON, 006h
    #define _T4CON??5        	 T4CON, 005h
    #define _T4CON??4        	 T4CON, 004h
    #define _T4CON??3        	 T4CON, 003h
    #define _T4CON??1        	 T4CON, 001h
    #define _T4CON??0        	 T4CON, 000h
    #define _T4CON??2        	 T4CON, 002h
    	INCLUDE	"LIGHTD~2.MAC"
    	INCLUDE	"C:\PBP2.60B\PBPPI14E.LIB"
    ; C:\PBP2.60B\16F1824.BAS  	00012	BANK0   $0020, $007F
    ; C:\PBP2.60B\16F1824.BAS  	00013	BANK1   $00A0, $00EF
    ; C:\PBP2.60B\16F1824.BAS  	00014	BANK2   $0120, $016F
    ; C:\PBP2.60B\16F1824.BAS  	00015	EEPROM  $F000, $F0FF
    ; C:\PBP2.60B\16F1824.BAS  	00016	LIBRARY "PBPPI14E"
    ; C:\PBP2.60B\16F1824.BAS  	00021	        include "PI14EEXT.BAS"
    ; C:\PBP2.60B\16F1824.BAS  	00028	        include "PBPPI14E.RAM"
    ; D:\FED\CLC\LIGHTD~2.PBP  	00012	@ __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _CPD_ON & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    	ASM?
    	ENDASM?
    ; D:\FED\CLC\LIGHTD~2.PBP  	00013	@ __config _CONFIG2, _WRT_ALL & _PLLEN_ON & _STVREN_ON & _BORV_25 & _LVP_OFF
    	ASM?
    	ENDASM?
    ; D:\FED\CLC\LIGHTD~2.PBP  	00017	OSCCON.7 = 1
    	MOVE?CT	001h, _OSCCON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00018	OSCCON.6 = 1
    	MOVE?CT	001h, _OSCCON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00019	OSCCON.5 = 1
    	MOVE?CT	001h, _OSCCON??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00020	OSCCON.4 = 1
    	MOVE?CT	001h, _OSCCON??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00021	OSCCON.3 = 0
    	MOVE?CT	000h, _OSCCON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00022	OSCCON.1 = 0
    	MOVE?CT	000h, _OSCCON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00023	OSCCON.0 = 0
    	MOVE?CT	000h, _OSCCON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00025	INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    ; C:\PBP2.60B\DT_INTS-14.BAS	00032	Asm
    	ASM?
    asm = 0
    ASM = 0
    pbp = 1
    PBP = 1
    YES = 1
    yes = 1
    NO = 0
    no = 0
    	ENDASM?
    ; C:\PBP2.60B\DT_INTS-14.BAS	00043	ASM
    	ASM?
      #define INT_INT   INTCON,INTF     ;-- INT External Interrupt
      #define RBC_INT   INTCON,RBIF     ;-- RB Port Change Interrupt
      #define TMR0_INT  INTCON,T0IF     ;-- TMR0 Overflow Interrupt 16F
      #define TMR1_INT  PIR1,TMR1IF     ;-- TMR1 Overflow Interrupt
      #define TMR2_INT  PIR1,TMR2IF     ;-- TMR2 to PR2 Match Interrupt
      #define TX_INT    PIR1,TXIF       ;-- USART Transmit Interrupt
      #define RX_INT    PIR1,RCIF       ;-- USART Receive Interrupt
      #define CMP_INT   PIR2,CMIF       ;-- Comparator Interrupt
      #define EE_INT    PIR2,EEIF       ;-- EEPROM/FLASH Write Operation Interrupt
      #define BUS_INT   PIR2,BCLIF      ;-- Bus Collision Interrupt
      #define PSP_INT   PIR1,PSPIF      ;-- Parallel Slave Port Read/Write Interrupt
      #define AD_INT    PIR1,ADIF       ;-- A/D Converter Interrupt
      #define SSP_INT   PIR1,SSPIF      ;-- Master Synchronous Serial Port Interrupt
      #define CCP1_INT  PIR1,CCP1IF     ;-- CCP1 Interrupt
      #define CCP2_INT  PIR2,CCP2IF     ;-- CCP2 Interrupt
    	ENDASM?
    ; C:\PBP2.60B\DT_INTS-14.BAS	00062	asm
    	ASM?
    INT_Source  macro  IFR, IFB, IER, IEB
        if ((IflagReg == IFR) && (IflagBit == IFB))
      list
    INT_Flag_Reg = IFR
    INT_Flag_Bit = IFB
    INT_Enable_Reg = IER
    INT_Enable_Bit = IEB
    Found = YES
    ;  nolist
    	ENDASM?
    ; C:\PBP2.60B\DT_INTS-14.BAS	00077	asm
    	ASM?
    GetIntInfo  macro  IflagReg, IflagBit
    Found = NO
    ; nolist
      ifdef INTF    ;----{ INT External Interrupt }----------------[INTCON, INTF]---
          INT_Source  INTCON, INTF, INTCON, INTE
      ifdef RBIF    ;----{ RB Port Change Interrupt }--------------[INTCON, RBIF]---
          INT_Source  INTCON, RBIF, INTCON, RBIE
      ifdef T0IF    ;----{ TMR0 Overflow Interrupt }-------------[INTCON, TMR0IF]---
          INT_Source  INTCON, T0IF, INTCON, T0IE
      ifdef TMR1IF  ;----{ TMR1 Overflow Interrupt }---------------[PIR1, TMR1IF]---
          INT_Source  PIR1, TMR1IF, PIE1, TMR1IE
      ifdef TMR2IF  ;----{ TMR2 to PR2 Match Interrupt }-----------[PIR1, TMR2IF]---
          INT_Source  PIR1, TMR2IF, PIE1, TMR2IE
      ifdef TXIF    ;----{ USART Transmit Interrupt }----------------[PIR1, TXIF]---
          INT_Source  PIR1, TXIF, PIE1, TXIE
      ifdef RCIF    ;----{ USART Receive Interrupt }------------------[PIR1 RCIF]---
              INT_Source  PIR1, RCIF, PIE1, RCIE
      ifdef CMIF    ;----{ Comparator Interrupt }--------------------[PIR2, CMIF]---
          ifdef PIR2
              INT_Source  PIR2, CMIF, PIE2, CMIE
              INT_Source  PIR1, CMIF, PIE1, CMIE
      ifdef EEIF    ;---{ EEPROM/FLASH Write Operation Interrupt }---[PIR2, EEIF]---
          ifdef PIR2
              INT_Source  PIR2, EEIF, PIE2, EEIE
              INT_Source  PIR1, EEIF, PIE1, EEIE
      ifdef BCLIF   ;----{ Bus Collision Interrupt }----------------[PIR2, BCLIF]---
          INT_Source  PIR2, BCLIF, PIE2, BCLIE
      ifdef PSPIF   ;--{ Parallel Slave Port Read/Write Interrupt }--[PIR1, PSPIF]--
          INT_Source  PIR1, PSPIF, PIE1, PSPIE
      ifdef ADIF   ;----{ A/D Converter Interrupt }------------------[PIR1, ADIF]---
          INT_Source  PIR1, ADIF, PIE1, ADIE
      ifdef SSPIF  ;----{ Master Synchronous Serial Port Interrupt }--[PIR1, SSPIF]-
          INT_Source  PIR1, SSPIF, PIE1, SSPIE
      ifdef CCP1IF ;----{ CCP1 Interrupt }-------------------------[PIR1, CCP1IF]---
          INT_Source  PIR1, CCP1IF, PIE1, CCP1IE
      ifdef CCP2IF ;----{ CCP2 Interrupt Flag }--------------------[PIR2, CCP2IF]---
          INT_Source  PIR2, CCP2IF, PIE2, CCP2IE
      list
      list
    	ENDASM?
    ; C:\PBP2.60B\DT_INTS-14.BAS	00142	ASM
    	ASM?
    ;---[Returns the Address of a Label as a Word]----------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]--------------------------------------
    CHKRP?T  macro reg, bit
            CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]---------------------
    INT_CREATE  macro
      local OverCREATE
        goto OverCREATE
    INT_ENTRY
        IF (CODE_SIZE <= 2)
            movwf   wsave       ; 1 copy W to wsave register
            swapf   STATUS,W    ; 2 swap status reg to be saved into W
            clrf    STATUS      ; 3 change to bank 0 regardless of current bank
            movwf   ssave       ; 4 save status reg to a bank 0 register
            movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
            movwf   psave       ; 6 save PCLATH reg to a bank 0 register
        EndIF
        movf      FSR,W         ; 7 move FSR reg to be saved into W reg
        movwf     fsave         ; 8 save FSR reg to a bank 0 register
    ;    clrf    STATUS          ; BANK 0
    PREV_BANK = 0
    List_Start
        RST?RP
        CHKRP?T  _Serviced
        bcf      _Serviced
        INT_LIST                ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
        CHKRP?T  _Serviced
        btfsc    _Serviced
        goto List_Start
        ifdef ReEnterUsed       ; if ReEnterPBP.bas was included in the main program
            CHKRP?T  _VarsSaved
            btfss    _VarsSaved   ; if PBP system vars have been saved
            goto     INT_EXIT
            GetAddress  INT_EXIT, _RetAddr
            L?GOTO   _RestorePBP   ; Restore PBP system Vars
    INT_EXIT
    PREV_BANK = 0
        MOVF    fsave,W         ; Restore the FSR reg
        MOVWF   FSR
        Movf    psave,w         ; Restore the PCLATH reg
        Movwf   PCLATH
        swapf   ssave,w         ; Restore the STATUS reg
        movwf   STATUS
        swapf   wsave,f
        swapf   wsave,w         ; Restore W reg
        Retfie                  ; Exit the interrupt routine
    OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    	ENDASM?
    ; C:\PBP2.60B\DT_INTS-14.BAS	00215	ASM
    	ASM?
    ;---[Add an Interrupt Source to the user's list of INT Handlers]----------------
    INT_Handler  macro  IntFlagReg, IntFlagBit, Label, Type, Reset
      list
        local AfterSave, AfterRestore, NoInt
            GetIntInfo   IntFlagReg, IntFlagBit
            if (Found == YES)
                CLRWDT
                CHK?RP   INT_Enable_Reg
                btfss    INT_Enable_Reg, INT_Enable_Bit  ; if the INT is enabled
                goto   NoInt
                CHK?RP   INT_Flag_Reg
                btfss    INT_Flag_Reg, INT_Flag_Bit      ; and the Flag set?
                goto     NoInt
        CHKRP?T  _Serviced
        bsf      _Serviced
                if (Type == PBP)                         ; If INT handler is PBP
                    ifdef ReEnterUsed
                        GetAddress  AfterSave, _RetAddr
                        L?GOTO  _SavePBP                 ; Save PBP system Vars
    AfterSave
                        clrf    STATUS
    PREV_BANK = 0
                        error ReEnterPBP must be INCLUDEd to use PBP interrupts
                GetAddress  AfterRestore, _RetAddr       ; save return address
                L?GOTO   Label                           ; goto the users INT handler
    AfterRestore
                clrf   STATUS
    PREV_BANK = 0
                if (Reset == YES)
                    CHK?RP   INT_Flag_Reg
                    bcf      INT_Flag_Reg, INT_Flag_Bit ; reset flag (if specified)
                error Interrupt Source (IntFlagReg,IntFlagBit) not found
    NoInt
            clrf   STATUS
    PREV_BANK = 0
    ;---[Returns from a "goto" subroutine]------------(RetAddr must be set first)---
    INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    ;---[Enable an interrupt source]------------------------------------------------
    INT_ENABLE  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              CHK?RP  INT_Flag_Reg
              bcf     INT_Flag_Reg, INT_Flag_Bit        ; clear the flag first
              bsf     INT_Enable_Reg, INT_Enable_Bit    ; enable the INT source
              error Cannot Enable (IntFlagReg,IntFlagBit)
    ;---[Disable an interrupt source]-----------------------------------------------
    INT_DISABLE  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              bcf     INT_Enable_Reg, INT_Enable_Bit    ; disable the INT source
              error Cannot Disable (IntFlagReg,IntFlagBit)
    ;---[Clear an interrupt Flag]---------------------------------------------------
    INT_CLEAR  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              CHK?RP  INT_Flag_Reg
              bcf     INT_Flag_Reg, INT_Flag_Bit       ; clear the INT flag
              error Cannot CLEAR (IntFlagReg,IntFlagBit)
    	ENDASM?
    ; D:\FED\CLC\LIGHTD~2.PBP  	00026	INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    ; C:\PBP2.60B\REENTERPBP.BAS	00015	   VarsSaved = 0
    	MOVE?CT	000h, _VarsSaved
    ; C:\PBP2.60B\REENTERPBP.BAS	00017	goto OverReEnter
    	GOTO?L	_OverReEnter
    ; C:\PBP2.60B\REENTERPBP.BAS	00042	SavePBP:                        ' Save all PBP system Vars
    	LABEL?L	_SavePBP
    ; C:\PBP2.60B\REENTERPBP.BAS	00043	  if VarsSaved = 0 then
    	CMPNE?TCL	_VarsSaved, 000h, L00001
    ; C:\PBP2.60B\REENTERPBP.BAS	00044	    R0_Save = R0        '  4/ 4
    	MOVE?WW	R0, _R0_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00045	    R1_Save = R1        '  4/ 8
    	MOVE?WW	R1, _R1_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00046	    R2_Save = R2        '  4/12
    	MOVE?WW	R2, _R2_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00047	    R3_Save = R3        '  4/16
    	MOVE?WW	R3, _R3_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00048	    R4_Save = R4        '  4/20
    	MOVE?WW	R4, _R4_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00049	    R5_Save = R5        '  4/24
    	MOVE?WW	R5, _R5_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00050	    R6_Save = R6        '  4/28
    	MOVE?WW	R6, _R6_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00051	    R7_Save = R7        '  4/32
    	MOVE?WW	R7, _R7_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00052	    R8_Save = R8        '  4/36
    	MOVE?WW	R8, _R8_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00053	    Flags_Save = FLAGS  '  2/38
    	MOVE?BB	FLAGS, _Flags_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00054	    GOP_Save = GOP      '  2/40
    	MOVE?BB	GOP, _GOP_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00055	    RM1_Save = RM1      '  2/42
    	MOVE?BB	RM1, _RM1_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00056	    RM2_Save = RM2      '  2/44
    	MOVE?BB	RM2, _RM2_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00057	    RR1_Save = RR1      '  2/46
    	MOVE?BB	RR1, _RR1_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00058	    RR2_Save = RR2      '  2/48
    	MOVE?BB	RR2, _RR2_Save
    ; C:\PBP2.60B\REENTERPBP.BAS	00059	    ASM
    	ASM?
            ifdef RS1
                MOVE?BB    RS1, _RS1_Save    ; 2/50
            ifdef RS2
                MOVE?BB    RS2, _RS2_Save    ; 2/52
            ifdef T1
                MOVE?WW    T1, _T1_Save    ; 4/56
            ifdef T2
                MOVE?WW    T2, _T2_Save    ; 4/60
            ifdef T3
                MOVE?WW    T3, _T3_Save    ; 4/64
            ifdef T4
                MOVE?WW    T4, _T4_Save    ; 4/68    Save Delay = 68us @4mhz
            endif                          ;                    13.6us @20mhz
    	ENDASM?
    ; C:\PBP2.60B\REENTERPBP.BAS	00080	    VarsSaved = 1
    	MOVE?CT	001h, _VarsSaved
    ; C:\PBP2.60B\REENTERPBP.BAS	00081	  endif
    	LABEL?L	L00001
    ; C:\PBP2.60B\REENTERPBP.BAS	00082	@ INT_RETURN
    	ASM?
     INT_RETURN
    	ENDASM?
    ; C:\PBP2.60B\REENTERPBP.BAS	00084	RestorePBP:
    	LABEL?L	_RestorePBP
    ; C:\PBP2.60B\REENTERPBP.BAS	00085	  if VarsSaved = 1 then
    	CMPNE?TCL	_VarsSaved, 001h, L00003
    ; C:\PBP2.60B\REENTERPBP.BAS	00086	    R0 = R0_Save
    	MOVE?WW	_R0_Save, R0
    ; C:\PBP2.60B\REENTERPBP.BAS	00087	    R1 = R1_Save
    	MOVE?WW	_R1_Save, R1
    ; C:\PBP2.60B\REENTERPBP.BAS	00088	    R2 = R2_Save
    	MOVE?WW	_R2_Save, R2
    ; C:\PBP2.60B\REENTERPBP.BAS	00089	    R3 = R3_Save
    	MOVE?WW	_R3_Save, R3
    ; C:\PBP2.60B\REENTERPBP.BAS	00090	    R4 = R4_Save
    	MOVE?WW	_R4_Save, R4
    ; C:\PBP2.60B\REENTERPBP.BAS	00091	    R5 = R5_Save
    	MOVE?WW	_R5_Save, R5
    ; C:\PBP2.60B\REENTERPBP.BAS	00092	    R6 = R6_Save
    	MOVE?WW	_R6_Save, R6
    ; C:\PBP2.60B\REENTERPBP.BAS	00093	    R7 = R7_Save
    	MOVE?WW	_R7_Save, R7
    ; C:\PBP2.60B\REENTERPBP.BAS	00094	    R8 = R8_Save
    	MOVE?WW	_R8_Save, R8
    ; C:\PBP2.60B\REENTERPBP.BAS	00095	    FLAGS = Flags_Save
    	MOVE?BB	_Flags_Save, FLAGS
    ; C:\PBP2.60B\REENTERPBP.BAS	00096	    GOP = GOP_Save
    	MOVE?BB	_GOP_Save, GOP
    ; C:\PBP2.60B\REENTERPBP.BAS	00097	    RM1 = RM1_Save
    	MOVE?BB	_RM1_Save, RM1
    ; C:\PBP2.60B\REENTERPBP.BAS	00098	    RM2 = RM2_Save
    	MOVE?BB	_RM2_Save, RM2
    ; C:\PBP2.60B\REENTERPBP.BAS	00099	    RR1 = RR1_Save
    	MOVE?BB	_RR1_Save, RR1
    ; C:\PBP2.60B\REENTERPBP.BAS	00100	    RR2 = RR2_Save
    	MOVE?BB	_RR2_Save, RR2
    ; C:\PBP2.60B\REENTERPBP.BAS	00101	    ASM
    	ASM?
            ifdef RS1
                MOVE?BB     _RS1_Save, RS1
            ifdef RS2
                MOVE?BB     _RS2_Save, RS2
            ifdef T1
                MOVE?WW     _T1_Save, T1
            ifdef T2
                MOVE?WW    _T2_Save, T2
            ifdef T3
                MOVE?WW    _T3_Save, T3
            ifdef T4
                MOVE?WW    _T4_Save, T4
            ifdef T5
                ERROR "Temp variables exceeding T4"
    	ENDASM?
    ; C:\PBP2.60B\REENTERPBP.BAS	00124	    VarsSaved = 0
    ; C:\PBP2.60B\REENTERPBP.BAS	00125	  ENDIF
    	LABEL?L	L00003
    ; C:\PBP2.60B\REENTERPBP.BAS	00126	@ INT_RETURN
    	ASM?
     INT_RETURN
    	ENDASM?
    ; C:\PBP2.60B\REENTERPBP.BAS	00128	OverReEnter:
    	LABEL?L	_OverReEnter
    ; D:\FED\CLC\LIGHTD~2.PBP  	00028	ASM
    	ASM?
            INT_Handler    TMR4_INT,  _PWM_UPDATE,   PBP,  yes
    	ENDASM?
    ; D:\FED\CLC\LIGHTD~2.PBP  	00035	@   INT_ENABLE   TMR4_INT     ; enable TMR4 interrupts
    	ASM?
    	ENDASM?
    ; D:\FED\CLC\LIGHTD~2.PBP  	00037	FVRCON.7 = 1
    	MOVE?CT	001h, _FVRCON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00038	FVRCON.5 = 1
    	MOVE?CT	001h, _FVRCON??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00039	FVRCON.4 = 0
    	MOVE?CT	000h, _FVRCON??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00040	FVRCON.3 = 0
    	MOVE?CT	000h, _FVRCON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00041	FVRCON.2 = 0
    	MOVE?CT	000h, _FVRCON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00042	FVRCON.1 = 1
    	MOVE?CT	001h, _FVRCON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00043	FVRCON.0 = 0
    	MOVE?CT	000h, _FVRCON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00045	ADCON1.6 = 0
    	MOVE?CT	000h, _ADCON1??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00046	ADCON1.5 = 1
    	MOVE?CT	001h, _ADCON1??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00047	ADCON1.4 = 0
    	MOVE?CT	000h, _ADCON1??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00048	ADCON1.2 = 0
    	MOVE?CT	000h, _ADCON1??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00049	ADCON1.1 = 1
    	MOVE?CT	001h, _ADCON1??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00050	ADCON1.0 = 1
    	MOVE?CT	001h, _ADCON1??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00052	TRISA = %11111011
    	MOVE?CB	0FBh, TRISA
    ; D:\FED\CLC\LIGHTD~2.PBP  	00053	TRISC = %00000000
    	MOVE?CB	000h, TRISC
    ; D:\FED\CLC\LIGHTD~2.PBP  	00054	PORTC = %00000000
    	MOVE?CB	000h, PORTC
    ; D:\FED\CLC\LIGHTD~2.PBP  	00056	BOOTCHECK:
    	LABEL?L	_BOOTCHECK
    ; D:\FED\CLC\LIGHTD~2.PBP  	00057	if FVRCON.6 = 0 then goto BOOTCHECK                 ; wait for PLL to stabilise
    	CMPNE?TCL	_FVRCON??6, 000h, L00005
    	GOTO?L	_BOOTCHECK
    	LABEL?L	L00005
    ; D:\FED\CLC\LIGHTD~2.PBP  	00059	TRISC.5 = 1                                         ; PWM1 io driver disable
    	MOVE?CT	001h, _TRISC??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00060	TRISC.3 = 1                                         ; PWM2 io driver disable
    	MOVE?CT	001h, _TRISC??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00061	TRISA.2 = 1                                         ; PWM3 io driver disable
    	MOVE?CT	001h, _TRISA??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00062	TRISC.1 = 1                                         ; PWM4 io driver disable
    	MOVE?CT	001h, _TRISC??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00063	PR6 = 255
    	MOVE?CB	0FFh, PR6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00065	APFCON1.0 = 0
    	MOVE?CT	000h, _APFCON1??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00066	CCP1CON.7 = 0
    	MOVE?CT	000h, _CCP1CON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00067	CCP1CON.6 = 0
    	MOVE?CT	000h, _CCP1CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00068	CCP1CON.3 = 1
    	MOVE?CT	001h, _CCP1CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00069	CCP1CON.2 = 1
    	MOVE?CT	001h, _CCP1CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00070	CCP1CON.1 = 0
    	MOVE?CT	000h, _CCP1CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00071	CCP1CON.0 = 0
    	MOVE?CT	000h, _CCP1CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00073	CCP2CON.7 = 0
    	MOVE?CT	000h, _CCP2CON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00074	CCP2CON.6 = 0
    	MOVE?CT	000h, _CCP2CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00075	CCP2CON.3 = 1
    	MOVE?CT	001h, _CCP2CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00076	CCP2CON.2 = 1
    	MOVE?CT	001h, _CCP2CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00077	CCP2CON.1 = 0
    	MOVE?CT	000h, _CCP2CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00078	CCP2CON.0 = 0
    	MOVE?CT	000h, _CCP2CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00080	CCP3CON.7 = 0
    	MOVE?CT	000h, _CCP3CON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00081	CCP3CON.6 = 0
    	MOVE?CT	000h, _CCP3CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00082	CCP3CON.3 = 1
    	MOVE?CT	001h, _CCP3CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00083	CCP3CON.2 = 1
    	MOVE?CT	001h, _CCP3CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00084	CCP3CON.1 = 0
    	MOVE?CT	000h, _CCP3CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00085	CCP3CON.0 = 0
    	MOVE?CT	000h, _CCP3CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00087	CCP4CON.7 = 0
    	MOVE?CT	000h, _CCP4CON??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00088	CCP4CON.6 = 0
    	MOVE?CT	000h, _CCP4CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00089	CCP4CON.3 = 1
    	MOVE?CT	001h, _CCP4CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00090	CCP4CON.2 = 1
    	MOVE?CT	001h, _CCP4CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00091	CCP4CON.1 = 0
    	MOVE?CT	000h, _CCP4CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00092	CCP4CON.0 = 0
    	MOVE?CT	000h, _CCP4CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00094	CCPTMRS0.7 = 1
    	MOVE?CT	001h, _CCPTMRS0??7
    ; D:\FED\CLC\LIGHTD~2.PBP  	00095	CCPTMRS0.6 = 0
    	MOVE?CT	000h, _CCPTMRS0??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00096	CCPTMRS0.5 = 1
    	MOVE?CT	001h, _CCPTMRS0??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00097	CCPTMRS0.4 = 0
    	MOVE?CT	000h, _CCPTMRS0??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00098	CCPTMRS0.3 = 1
    	MOVE?CT	001h, _CCPTMRS0??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00099	CCPTMRS0.2 = 0
    	MOVE?CT	000h, _CCPTMRS0??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00100	CCPTMRS0.1 = 1
    	MOVE?CT	001h, _CCPTMRS0??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00101	CCPTMRS0.0 = 0
    	MOVE?CT	000h, _CCPTMRS0??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00103	CCP1AS = 0
    	MOVE?CB	000h, CCP1AS
    ; D:\FED\CLC\LIGHTD~2.PBP  	00104	CCP2AS = 0
    	MOVE?CB	000h, CCP2AS
    ; D:\FED\CLC\LIGHTD~2.PBP  	00105	CCP3AS = 0
    	MOVE?CB	000h, CCP3AS
    ; D:\FED\CLC\LIGHTD~2.PBP  	00108	TRISC.5 = 0                                         ; PWM1 io driver enable
    	MOVE?CT	000h, _TRISC??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00109	TRISC.3 = 0                                         ; PWM2 io driver enable
    	MOVE?CT	000h, _TRISC??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00110	TRISA.2 = 0                                         ; PWM3 io driver enable
    	MOVE?CT	000h, _TRISA??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00111	TRISC.1 = 0                                         ; PWM4 io driver enable
    	MOVE?CT	000h, _TRISC??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00113	T6CON.6 = 1                                         ; T6 postscale
    	MOVE?CT	001h, _T6CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00114	T6CON.5 = 1                                         ; T6 postscale
    	MOVE?CT	001h, _T6CON??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00115	T6CON.4 = 1                                         ; T6 postscale
    	MOVE?CT	001h, _T6CON??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00116	T6CON.3 = 1                                         ; T6 postscale
    	MOVE?CT	001h, _T6CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00117	T6CON.1 = 1                                         ; T6 Post Scale
    	MOVE?CT	001h, _T6CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00118	T6CON.0 = 1                                         ; T6 post scale
    	MOVE?CT	001h, _T6CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00119	T6CON.2 = 1                                         ; T6 ON
    	MOVE?CT	001h, _T6CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00121	T4CON.6 = 1                                         ; T4 postscale
    	MOVE?CT	001h, _T4CON??6
    ; D:\FED\CLC\LIGHTD~2.PBP  	00122	T4CON.5 = 1                                         ; T4 postscale
    	MOVE?CT	001h, _T4CON??5
    ; D:\FED\CLC\LIGHTD~2.PBP  	00123	T4CON.4 = 1                                         ; T4 postscale
    	MOVE?CT	001h, _T4CON??4
    ; D:\FED\CLC\LIGHTD~2.PBP  	00124	T4CON.3 = 1                                         ; T4 postscale
    	MOVE?CT	001h, _T4CON??3
    ; D:\FED\CLC\LIGHTD~2.PBP  	00125	T4CON.1 = 1                                         ; T4 Post Scale
    	MOVE?CT	001h, _T4CON??1
    ; D:\FED\CLC\LIGHTD~2.PBP  	00126	T4CON.0 = 1                                         ; T4 post scale
    	MOVE?CT	001h, _T4CON??0
    ; D:\FED\CLC\LIGHTD~2.PBP  	00127	T4CON.2 = 1                                         ; T4 ON
    	MOVE?CT	001h, _T4CON??2
    ; D:\FED\CLC\LIGHTD~2.PBP  	00128	PR4 = 255
    	MOVE?CB	0FFh, PR4
    If you read the include file, it will walk you through it.
    ' --- IF any of these three lines cause an error ?? Simply Comment them out to fix the problem ----
    wsave3 var byte $1A0 SYSTEM ' location for W if in bank3
    Actually, i found a bug...
    Cool, no one's done that for probably a year.
    What's the bug?
    One of those PEBKAC one I guess, you know those you hit only once a decade Yeah right
