ADC on 12f675?
Results 1 to 11 of 11
Thread: ADC on 12f675?
    Feb 2005
    Question ADC on 12f675?
    I have the attached circuit and the following program:
    TRISIO=%1 'Pic 12F675
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    cmcon=7
    ansel=1
    ADCON0=131
    number VAR word
    Pause 100
    Loop:
    ADCIN 0, number ' (0-1023)
    IF number > 0 AND number < 400 Then
    GPIO.1=1
    GPIO.2=0
    GPIO.4=0
    EndIF
    IF number > 401 AND number < 800 Then
    GPIO.1=0
    GPIO.2=1
    GPIO.4=0
    EndIF
    IF number > 801 AND number < 1024 Then
    GPIO.1=0
    GPIO.2=0
    GPIO.4=1
    EndIF
    GoTo loop
    it does not work, any ideas?
    Im trying to do my 1st ADC program, a simpler working one that make me understand the concept is welcome too!!!
    Thanks a bunch
    Dec 2003
    Wichita KS
    Hello Peu,
    Peu>>TRISIO=%1 'Pic 12F675<
    TRISIO is your input output switch.
    I did not go through all of your code, but this put a flag up to me.
    TRISIO=%XXXXXXX is a binary representation of the switches.
    I question the usagle of just TRISIO=%1
    You are using GPIO.0 as your input, thus I would assign TRISIO one of the following:
    TRISIO=%00000001
    or
    TRISIO=1
    Notice I did not put the % in front of the second one.
    Because 1 = %00000001
    I am not saying this is your entire problem. But you may want to check it out.
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    Feb 2005
    I tried but it did not worked, I think Im missing something, but I can't figure it out.
    pointers to adc examples for the 12f675/683 are welcome. Thanks
    Hi,Peu
    I remember CMCON = 7 is used on my 16F628 to DISABLE all Analogic inputs ...
    Verify if the same config. word for 12F675...
    your Pb seems to be here ...
    Feb 2005
    with this new header:
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    'cmcon=7
    ADCON0=%11000011 'dec 195
    ansel=%001
    it still does not work ... any idea?
    All you need to set is ADCON0.7 = 1 for right justification. PBP will
    handle channel select bits and ADON.
    Try this.
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    number VAR word
    CMCON = 7          ' Comparators off
    ANSEL = %00000001  ' GPIO.0 A/D in, rest digital
    ADCON0.7 = 1       ' Right justify for 10-bit
    TRISIO = %00000001 ' GPIO.0 = input, rest outputs
        Pause 100
    Loop:
        IF (number > 0) AND (number < 400) Then
          GPIO 1=1
          GPIO.2=0
          GPIO.4=0
        EndIF
        IF (number > 401) AND (number < 800) Then
          GPIO.1=0
          GPIO.2=1
          GPIO.4=0
        EndIF
        IF (number > 801) AND (number < 1024) Then
          GPIO.1=0
          GPIO.2=0
          GPIO.4=1
        EndIF
        number = 0
        GoTo loop
    Assuming you have your config fuse options & oscillator setup
    properly, this should work.
    You can find several more 12F675 A/D examples here;
    http://www.microengineeringlabs.com/...ples.htm#x4pbp
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Smile
    here's an example ... with explanations !!!
    Feb 2005
    Bruce:
    Thanks var word
    loop:
    thanks=$FFFF '
    it works, now I need to adjust the code because the led dont work as expected, but I put a serout after the adcin and the terminal reads the different values OK!!!
    goto loop
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    number VAR word
    GPIO = %00000000 ' Initialize outputs
        PAUSE 100
    Loop:
          GPIO = %00000010
          'GPIO.1=1
          'GPIO.2=0
          'GPIO.4=0
        EndIF
          GPIO = %00000100
          'GPIO.1=0
          'GPIO.2=1
          'GPIO.4=0
        EndIF
          GPIO = %00010000
          'GPIO.1=0
          'GPIO.2=0
          'GPIO.4=1
        EndIF
        number = 0
        GoTo loop
    -Bruce
    tech at rentron.com
    Feb 2005
    Thumbs up
    MASTER !
    I trully appreciate your prompt answers, thank you very much !!!
    Default ADC with tone out and hysteresis
    Hi
    After looking to the examples above I have the following I want to do
    As this is my first ADC code I need some tips and maybe some help
    I want to do the following
    ADC on GPIO.0 8 bit
    I have a DC voltage between 0.5V and 2V approx
    Which is varying all the time
    I need to encode the DC variation by a tone between 67hz and 250hz
    with 2-4 hertz incremental/value
    The DC values needs to be stored in EEprom at setup
    (example button is pushed at powerup to enter setup)
    30 DC values should correspond to 30 tones (30 tone's might be set fix in the code)
    So example:
    0.55V = 67hz
    0.64V = 71hz
    0.71V = 74hz
    etc...
    Once setup and running: if a DC value is between or equal next value it has to
    output the tone ( set in the code)
    with a kind of hysteresis for the tone duration and before next sample)
    and a Serout to check the values
    Can anyone help me ?
    Walter
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 02:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 15:33
  3. ADC value with 2 decimals on an LCD
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2005, 15:54
  4. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
  5. Serial LCD on 12F675
    By anj in forum mel PIC BASIC Pro
    Last Post: - 31st March 2004, 23:11
