16F1827 voltage issue
Results 1 to 8 of 8
    According to my calc, to run LED's from 5V source you will need ~85 Ohm resisters in series for each led between the LED annode and the pic IO port to reduce the current down to 20mA each...
    Thats assuming the LED's have a drive voltage of 3.3V
    to work it out...
    5 - 3.3 = 1.7V diference
    now use V=IR re-aranged to R=V/I
    Where,
    V = voltage diference
    I = Current in amps (mA is 1/1000A or 0.001A)
    R = Resistance in ohms
    I have 6 LEDs. The LEDS represent 2 H-bridges with 2 direction controls and 1 PWM per bridge. The resistors were 70 ohms, I changed all resistors to 220. It still did the same reset condition. I reprogrammed the board a few times changing nothing but fuse settings and It seems to work now. I have no idea why....I just flipped them one way and then the other and downloaded it.
    Nick
    An eye to the default value of the LVP bit ???
