controlling a hotwire
Results 1 to 32 of 32
    Aug 2010
    Maryland, USA
    Or a BT137??
    -Bert
    Hi, Bert
    I recall a SCR switching circuit to control the avarage voltage across a motor for a simple speed control.
    Halas it uses the Counter EMF of the motor ...
    The trick here is to use PWM and sample the wire resistance ( needs wire with a PTC ! ) while PWM is off ...
    What is PTC?
    Thermistor I guess. ICL
    Aug 2010
    Maryland, USA
    Default Re: controlling a hotwire
    Hello all, I am back to trying to get this done. Any suggestions on the transformer in the melabs example? I don't need the power supply side, so really I guess I just need the zero crossing sync.
    So basiclly, a logic level TRAIC (as linked by Dave) connected to an output and a way to detect the Zero crossing is all I need, Yes?
    -Bert
    Apr 2011
    Exactly.
    The transformer must be rated for at least the maximum power you would expect to use plus a margin for safety. Since the VA rating defines the power, you could be very adaptable on the choice of transformer in terms of volts and current but, generally speaking, keeping the volts low (<24VAC) and the current high (probably around 3A to 5A) is safer for the user.
    There would be a quite large selection available on the likes of eBay if you search.
    Aug 2010
    Maryland, USA
    half asleep, but here is my beginning. Looking for some help here if anyone wants to help me fix this
    Name:  berts dimmer - needs help.bmp
    -Bert
    Apr 2011
    What is PTC?
    Positive Temperature Co-efficient
    when the resistance increases as the temperature does.
