Thanks Jerson for the schematic.
Thanks Joe for the tips, never good business to hurt the buyer. Although the wire supply will never be available from me, just too much liability to be fun. This is just for my pleasure. (never the less, no fun getting "bit")
-Bert
I use the MCT6 opto-coupler a lot in 5vdc circuits.
Resistor is easy, 330R like most LED.
Very interesting read here on optos:
http://www.jaycar.com.au/images_uploaded/optocoup.pdf
Didn't know about using a reverse diode on input side as added protection, nice:
In some circuits, there may be a chance that at times the driving voltage fed to the input LED could have reversed polarity (due to a swapped cable connection, for example).
This can cause damage to the device, because optocoupler LEDs tend to have quite a low reverse voltage rating: typically only 3 - 5V. So if this is a possibility, a reversed polarity diode should be connected directly across the LED...
There's opto with dual LED inside as well.
Exactly, that's why I like the MCT6.
Now if you want to go quad:
http://parts.digikey.com/ca/1/140440...pct4216-a.html
Bert, any chance of pics of the machine?
I will see what I can do. I'm not sure I have any right this second that will do it justice.
-Bert
