controlling a hotwire
Results 1 to 32 of 32
    Aug 2010
    Maryland, USA
    Default controlling a hotwire
    I know there are plenty of circuits on the net for this, but I have not found 1 to make me happy yet. Heres the set-up:
    My wire is 19 ohms. This is measured not calculated.
    My goal is around 50W. I think I remember this from earlier testing of a shorter wire.
    Trying to avoid a transformer.
    I want to control the heat (crudly no precision needed here) using a PIC. I am looking for the least expensive way. BTW without the PIC requirment a light dimmer would be just fine.
    Now WAY back in collage, I recall a SCR switching circuit to control the avarage voltage across a motor for a simple speed control. Thats about all I remember from it.
    Any thoughts on how I can accomplish this? Of course I can find SCR circuits, but maybe there is a better choice now days? It doesn't have to be clean the wire will avarage the heat so DC is not needed.
    My reason for wanting to run direct from 120 is if I can raise the heat to 75W or so, I can clean (burn off the foam) the wire between cuts.
    EDIT: Just dawned on me the question could/should be simply "How to control a 100W light bulb with a PIC?"
    -Bert
    Aug 2010
    Maryland, USA
    Thanks Dave, Can't seem to get the app note to load, but very good info!!
    If you can edit, I can too thanks for the melabs link. Maybe I should go and read through the stuff there sometime. This seems exactly what I need!
    -Bert
    This one?
    http://ww1.microchip.com/downloads/e...tes/40171a.pdf
    Loads here, I could email it to you...
    Aug 2010
    Maryland, USA
    Must have need you to get it jumpstarted. Any ideas for the TRIAC? looking for the one listed in the app note now, no joy at digikey. No part number on Mister_e (tm) circuit.
    -Bert
    A big one
    http://www.mouser.com/Search/Refine....rd=logic+triac
    Maybe the BTA12 ?
    Aug 2010
    Maryland, USA
    Or a BT137??
    -Bert
    Hi, Bert
    Halas it uses the Counter EMF of the motor ...
    The trick here is to use PWM and sample the wire resistance ( needs wire with a PTC ! ) while PWM is off ...
    What is PTC?
    Thermistor I guess. ICL
    Aug 2010
    Maryland, USA
    Default Re: controlling a hotwire
    Hello all, I am back to trying to get this done. Any suggestions on the transformer in the melabs example? I don't need the power supply side, so really I guess I just need the zero crossing sync.
    So basiclly, a logic level TRAIC (as linked by Dave) connected to an output and a way to detect the Zero crossing is all I need, Yes?
    -Bert
    Apr 2011
    What is PTC?
    Positive Temperature Co-efficient
    when the resistance increases as the temperature does.
    Apr 2011
    Exactly.
    The transformer must be rated for at least the maximum power you would expect to use plus a margin for safety. Since the VA rating defines the power, you could be very adaptable on the choice of transformer in terms of volts and current but, generally speaking, keeping the volts low (<24VAC) and the current high (probably around 3A to 5A) is safer for the user.
    There would be a quite large selection available on the likes of eBay if you search.
    Aug 2010
    Maryland, USA
    half asleep, but here is my beginning. Looking for some help here if anyone wants to help me fix this
    Name:  berts dimmer - needs help.bmp
    -Bert
    The cool thing of Triac is they often come short when they burn. So ask yourself if it's safe to plug it to the Main first. If the wire break... how dangerous it will be if someone try to change it LIVE.
    Kinda stuff like that
    Bombay, India
    I recommend you look up the MOC3021 opto-triac to interface your triac to the PIC. Your current scheme does not seem workable.
    Aug 2010
    Maryland, USA
    About my schematic: The values for the resistors are just the default values. I know they are not correct. The cap for the input to the opto's, I have no idea what value this should be. Also have no idea yet as to which opto style I want for the zero crossing side of things. Maybe neither? And I see I have connected the top opto incorrectly. I ment to groung the emitter and take the signal from the collector.
    @ Steve, Are you trying to remind me I need a fuse on the wire side?
    @Jerson, I am under the impression using a logic Triac, with 10mA gate will work as I drew it. If I am wrong about this, feel free to tell me and I will add the opto.
    @ Moderators, if this should now be moved to the schematic section, please move it. Thanks
    Last edited by cncmachineguy; - 4th May 2011 at 13:55. Reason: added message to mods
    -Bert
    Bombay, India
    Hi Bert
    I was not sure I had something that I could screen-grab. But, here it is. The opto input was used with a 12V circuit, however, you may use 5V and scale the resistor accordingly.
    Hi Bert,
    I think Steve is saying to include a circuit to protect the operator from electrical shock, GFI and proper machine grounding so you do not become roasted.
    Aug 2010
    Maryland, USA
    Thanks Jerson for the schematic.
    Thanks Joe for the tips, never good business to hurt the buyer. Although the wire supply will never be available from me, just too much liability to be fun. This is just for my pleasure. (never the less, no fun getting "bit")
    -Bert
    I use the MCT6 opto-coupler a lot in 5vdc circuits.
    Resistor is easy, 330R like most LED.
    Very interesting read here on optos:
    http://www.jaycar.com.au/images_uploaded/optocoup.pdf
    Didn't know about using a reverse diode on input side as added protection, nice:
    In some circuits, there may be a chance that at times the driving voltage fed to the input LED could have reversed polarity (due to a swapped cable connection, for example).
    This can cause damage to the device, because optocoupler LEDs tend to have quite a low reverse voltage rating: typically only 3 - 5V. So if this is a possibility, a reversed polarity diode should be connected directly across the LED...
    There's opto with dual LED inside as well.
    Exactly, that's why I like the MCT6.
    Now if you want to go quad:
    http://parts.digikey.com/ca/1/140440...pct4216-a.html
    Bert, any chance of pics of the machine?
    Aug 2010
    Maryland, USA
    I will see what I can do. I'm not sure I have any right this second that will do it justice.
    -Bert
    Aug 2010
    Maryland, USA
    Heres a pic. If you look close, you can see the wire. It is connected to the black arm on the left side of the pic.
    Name:  pic of the machine before A mods.jpg
    Not sure why I can't make the pic show up without clicking the link. Hmmm
    -Bert
    Dang! It's quite a machine you built there. Congrats
    Aug 2010
    Maryland, USA
    Thanks. Yesterday was the 1 year anniversary of its conception. There have been more mods since that pic, but it is pretty close. Working on a new head now.
    Now what am I doing wrong to insert the pic inline? I click the "insert inline" button, and I get the link view. Don't click that button, and I get an attachment.
    -Bert
    [IMG]paste the attachement link here[/IMG]
    Aug 2010
    Maryland, USA
    [IMG]Name:  homer_simpson_doh_02.gif
    Now who gets no love?
    -Bert
    That is one cool machine!
    You need the whole link in between your brackets. I know that is a little different than it used to be. Crown Hill is going to try to fix that. But until then:
    http://www.picbasic.co.uk/forum/atta...7&d=1304642840
    Then you can:
