Use of HIGH and LOW for pin outputs
Results 1 to 8 of 8
    I would add ...
    What if you replace the Relays by LEDs + 220 ohms resistors ???
    I do hope relays are equipped with their freewheel diode ... and NOT powered from the Pic 5v supply ...
    PS : as the program runs fine aboard my EasyPic5 with leds as outputs ... we could reasonnably suppose it's a HARDWARE issue ...
    Aug 2010
    Default Schematic
    Thanks Guys -
    I am scouring through the hardware. Attached is the schematic ...
    Aug 2010
    Default 1 bad $.50 transistor
    Can really mess up a few days...
    Thanks to all for the support. I guess the fact that when written with binary logic the program worked fine - it threw me for a loop and took focus off the hardware. My apologies ...
