Arrays calling Arrays
Results 1 to 5 of 5
    Alabama,USA
    Default Arrays calling Arrays
    My project is to determine the %moisture content of grain in storage. I’m using 1-Wire DS2438 and Honeywell HIH-4000 RH sensors inside of the grain. I have a number of sensors on each string. All devices are working good using individual SN to address each device. I have ample RAM but I’m running out of CODE space. To reduce the program size I need to be able to use an array of some kind to be called by a variable residing in the routine to address each 1-Wire device in secession so I can loop through a single routine rather than have multiple routines. Instead of using:
    OWOUT  DataPin, 1, [MatchRom,$26,$7A,$BA,$11,$01,$00,$00,$D8, ConvertV]
    I would like to use:
    OWOUT DataPin,1,[MatchRom,  OW_Loop_VAR  , ConvertV]
        OW_Loop_var   VAR   BYTE [8]
        OWbuffer1    VAR  BYTE[8]   ;SN first sensor
        OWbuffer1[0]= $26
        OWbuffer1[1]= $7A
        OWbuffer1[2]= $BA
        OWbuffer1[3]= $11
        OWbuffer1[4]= $01
        OWbuffer1[5]= $00
        OWbuffer1[6]= $00
        OWbuffer1[7]= $D8
        OWbuffer2    VAR  BYTE[8]   ;SN second sensor
        OWbuffer2[0]= $26
        OWbuffer2[1]= $A7
        OWbuffer2[2]= $AB
        OWbuffer2[3]= $11
        OWbuffer2[4]= $10
        OWbuffer2[5]= $00
        OWbuffer2[6]= $00
        OWbuffer2[7]= $E8
    OW_Loop_var = OWbuffer1
    GOSUB  OWroutine
    OW_Loop_var = OWbuffer2
    GOSUB  OWroutine
    OWrutine:
    OWOUT DataPin,1,[MatchRom,  OW_Loop_var , ConvertV]
    It seems to me this would work.  As a test I tried:
    OWOUT DataPin,1,[MatchRom, OWbuffer1, ConvertV]
    But it doesn’t work and I can’t seem to figure out how to make this happen. I’ve been reading posts on strings, arrays, EXT, and everything else I could find but I’ve seen nothing that resembles what I’m trying to do. Assistance please.
    Last edited by ScaleRobotics; - 4th February 2011 at 19:13. Reason: added code tags
    I've never played with the 1-wire commands but according to the manual you should be able to use the STR modifier to send an array of bytes out. So, an educated guess is something like:
    OWbuffer VAR BYTE[8]           ;Array for outgoing data
    'Assign values for sensor 1 to the array.
    OWbuffer[0]= $26 : OWbuffer[1]= $7A
    OWbuffer[2]= $BA : OWbuffer[3]= $11
    OWbuffer[4]= $01 : OWbuffer[5]= $00
    OWbuffer[6]= $00 : OWbuffer[7]= $D8
    GOSUB OWRoutine    'Send it
    'Assign values for sensor 2 to the array.
    OWbuffer[0]= $26 : OWbuffer[1]= $A7
    OWbuffer[2]= $AB : OWbuffer[3]= $11
    OWbuffer[4]= $10 : OWbuffer[5]= $00
    OWbuffer[6]= $00 : OWbuffer[7]= $E8
    OWRoutine:
      OWOUT DataPin,1,[MatchRom, STR OWBuffer \8, ConvertV]
    This way you only have one "instance" of the OWOUT command which should save you a couple of words compared to having 26 of them (if that's what you currently have).
    Alabama,USA
    Default Reply to Henrik
    Henrik,
    thanks for the reply. I've tried String modifiers to send 1-wire and it doesn't work. I use String modifiers to recieve data and it works fine. It seems the method should work in both directions.
    OWIN DataPin, 2, [STR DSbuffer\9 ] this work fine - recieve data from 1-Wire device
    OWOUT DataPin, 1, [MatchRom, STR OWbuffer\8, ConverV] doesn't work - send 1-Wire
    OWOUT DataPin, 1, [MatchRom, $26, $....... .......$D8, ConvertV] this works - send 1-Wire
    I'm not sure if the PBP comand can handle the string not enclosed in brakets. I'll keep working with this and get back to you. Thanks agin.
    Last edited by MOUNTAIN747; - 25th January 2011 at 21:03. Reason: correct error in numbers
    Alabama,USA
    Default follow up
    OK, I got it. A small error in the method I was using to set up the 1-Wire command. The STR modifier works fine. This will save a lot of code space. Hanrik, thanks for your reply which make me work on the STR method until I got it right!
    Great, I'm glad you got it going!
    Another way might be to use the DATA statement to save the values for each sensor to onboard EEPROM and then use a FOR-NEXT loop to read them out and stuff them into the OWBuffer array. Depending on the number of sensor "strings" you have it probably save you even more code space - provided your chip has enough EEPROM space of course.
