How to make a word as decimal in if then else statement
Results 1 to 17 of 17
    Jan 2011
    Default How to make a word as decimal in if then else statement
    Hello there!
    I'm pretty new here and pretty new with PICBasic, but I can tell you, I love it to work with it. Maybe my english is not so good but I'm doing my best!
    Some problems I see in my programming but i can't fix them...
    I need to know how to use a WORD in a DECimal If then Else statement. I've seen that "if DEC name = ...." wil absolutely not work. "If @name = ..." doens't work eather.
    Can anyboody tell me how i can solve this problem so i can go futher?
    Thanks a lot.
    Cheers.
    Your question is not so clear ...
    so : could you post the line ( or snippet ) you try to write and which doesn't work or compile ???
    I think you try to test CHARACTERS in a string ... but can you confirm ?
    Jan 2011
    Thanks for replying...
    Well. Thiis will work but reply's on LCD as a ASCII code:
    Print at 2, 1, Temp ; Read temp from a dS1820
    and this will works to convert the ASCII code to a normal celcius:
    Print at 2, 1, DEC Temp ; Read temp from a dS1820
    Now i want to do an if then else statement on the Temp var. If I only take this code:
    IF Temp = ... THEN
    the Temp var will only reads the ASCII code, but I want the source to read the celcius in the if statement, and not the ASCII code...
    I hope this makes it clearer.
    Are you sure you posted on the right forum ???
    I'm not ...
    Jan 2011
    I am not sure... As I said... my english is not really good :P But if somebody can move it for me.. please
    Quote Originally Posted by jeroeni View Post
    Are you using Pic Basic (PRO) ?
    Jan 2011
    Yeah, I'm using the pro version.
    Your lines look to be an uncontrolled mix of Basic and C languages ...
    So, it will be rather difficult to help you ...
    BTW "Jeroen" ... that reminds me something...
    what's your mother language ???
    I'd bet Dutch ...
    Jan 2011
    You're correct. I'm from Holland, a dutch guy...
    Jan 2011
    I will explain what I am trying to do... maybe it helps... in bad english, lol
    I've got 2 components, a DS1820 and a simple LED, both on other ports.
    When the DS1820 gets on 21,2celcius for example, the LED must blink, on 21,2+ the LED stays on, on 21,2- the LED turns off. The code I've got to control the DS1820 is:
    Above clear:
    SYMBOL Convert      = $44
    SYMBOL RdScratchPad = $BE
    SYMBOL SkipROM      = $CC
    SYMBOL Graad        = 223
    SYMBOL DS1820       = PORTA.1
    SYMBOL verwarming   = PORTA.6
    DIM Temp            AS WORD
    DIM Remain          AS BYTE
    DIM Slope           AS BYTE
    DIM BD1             AS BYTE
      OWRITE DS1820, 1, [SkipROM, Convert]
      OWRITE DS1820, 1, [SkipROM, RdScratchPad]
      OREAD  DS1820, 2, [Temp.LOWBYTE, Temp.HIGHBYTE, BD1, BD1, BD1, BD1, Remain, Slope] ',CRC]
      Temp = (((Temp >> 1) * 100) - 25) + (((Slope - Remain) * 100) / Slope)
      PRINT AT 1, 1, DEC Temp / 100, ".", DEC1 Temp / 10, Graad, "C  "
    [edit]
    by the way, verwarming is dutch... but doens't mather... it's just a symbol
    [/edit]
    But how can i control the LED with the code above? I used a IF then ELSE statement on Temp but Temp shows only symbols (not with DEC in front of it at the PRINT line, so not on LCD with that code)
    [edit2]
    When i use this, just for example what Temp do without DEC, I get the most funnyest symbols and icons on LCD
      PRINT AT 1, 1, Temp
    Anyhow... I need to put it in a If then Else statement... to control the led
    [/edit2]
    Above clear:
    SYMBOL RdScratchPad= $BE
    SYMBOL Graad        = 223
    DIM Temp            AS WORD
    DIM Remain          AS BYTE
    DIM Slope           AS BYTE
    DIM BD1             AS BYTE
    [edit]
    [/edit]
    Try to use PBP commands for the words I've put in RED ...
    Will work much better ... ... IF YOU USE PICBASIC PRO, WHICH IS NOT THE CASE ...
    calm down Alain
    jeroeni seems you're using another variant of PICBasic compiler, to me it looks like Proton Picbasic whose forum is located at the following link
    http://www.protonbasic.co.uk/forum.php?
    HTH
    Hi, Steve
    Sorry ... I couldn't recognise this one ... which is running fine.
    ' One-wire temperature for PROTON Board and DS1820
    Include "PROTON_4.INC"
    Dim Temperature As Word ' Temperature storage
    Dim Count_remain As Byte ' Count remaining
    Dim Count_per_c As Byte ' Count per degree C
    Dim Dum As Byte ' Dummy variable to pad OWIN
    Symbol DQ = PORTC.0 ' One-wire data pin
    DelayMS 500 ' Wait for PICmicro to stabilise
    Cls
    Mainloop:
    OWrite DQ, 1, [$CC, $44] ' Start temperature conversion
    While ORead DQ, 4 = 0 : Wend ' Check for still busy converting
    OWrite DQ, 1, [$CC, $BE] ' Read the Temperature
    ORead DQ, 0, [Temperature.LowByte, Temperature.HighByte, Dum,Dum,Dum,Dum, Count_remain, Count_per_c]
    ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    Temperature = (((Temperature >> 1) * 100) - 25) + (((Count_per_c - Count_remain) * 100) / Count_per_c)
    Print $FE, 1, Dec (Temperature / 100), ".", Dec2 Temperature, " C"
    ' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    Temperature = (Temperature */ 461) + 3200
    Print $FE, $C0, Dec (Temperature / 100), ".", Dec2 Temperature, " F"
    DelayMS 1000 ' Display once a second
    GoTo Mainloop ' Do it forever
    mackrackit
    jeroeni
    Ok, Ok ...
Size:  4.0 KB . . . . . . . . . .
    Jan 2011
    Smile
    Sorry, i guess i misunderstoot... PicBasic = program language and proton ide is the compiler, or is my mind freaking out with me now ? :P
    No, your mind is not freaking out but this is not the forum for Proton.
    It's often confusing as there are several BASIC-compilers for PIC available from different vendors, many of them with the phrasing or names like PICBasic.
    It doesn't get easier by the fact the THIS forum (which is for the PICBASIC compiler from MELABS) are hosted by Crownhill which are the developers of the Proton compiler.....
    For Proton specific questions you might have better luck at the Proton forum.
    With that said, and without knowing Proton the DEC modifier (at least in PBP) is used to convert the value contained in a variable to ASCII text in order to print to a display or serial terminal etc. If you do something like Temp = 100 the variable called Temp will contain the value 100. Now you can do stuff like
    If Temp > 125 then Goto CoolDown
    If Temp < 75 then Goto HeatUp
    But if you want to display the value of Temp on a display or terminal simply saying LCDOUT Temp (PRINT Temp in your case) will display the letter 'd' because 100 is the ASCII code for 'd'
    In order to display 100 the compiler needs to convert the value 100 into the text '1' '0' '0' and THAT is what the DEC modifier does.
    Jan 2011
    Okay thanks a lot. I will figure it out.
    Have a great day!
    Cheers
