How to make a word as decimal in if then else statement
Results 1 to 17 of 17
    Jan 2011
    Default How to make a word as decimal in if then else statement
    Hello there!
    I'm pretty new here and pretty new with PICBasic, but I can tell you, I love it to work with it. Maybe my english is not so good but I'm doing my best!
    Some problems I see in my programming but i can't fix them...
    I need to know how to use a WORD in a DECimal If then Else statement. I've seen that "if DEC name = ...." wil absolutely not work. "If @name = ..." doens't work eather.
    Can anyboody tell me how i can solve this problem so i can go futher?
    Thanks a lot.
    Cheers.
    Your question is not so clear ...
    so : could you post the line ( or snippet ) you try to write and which doesn't work or compile ???
    I think you try to test CHARACTERS in a string ... but can you confirm ?
    Jan 2011
    Thanks for replying...
    Well. Thiis will work but reply's on LCD as a ASCII code:
    Print at 2, 1, Temp ; Read temp from a dS1820
    and this will works to convert the ASCII code to a normal celcius:
    Print at 2, 1, DEC Temp ; Read temp from a dS1820
    Now i want to do an if then else statement on the Temp var. If I only take this code:
    IF Temp = ... THEN
    the Temp var will only reads the ASCII code, but I want the source to read the celcius in the if statement, and not the ASCII code...
    I hope this makes it clearer.
    Are you sure you posted on the right forum ???
    I'm not ...
    Jan 2011
    I am not sure... As I said... my english is not really good :P But if somebody can move it for me.. please
    Quote Originally Posted by jeroeni View Post
    Are you using Pic Basic (PRO) ?
