Interrupt on RB port change with PIC18F23K20
Results 1 to 7 of 7
    You are close, you have many of the elements required.
    Go to your manual and take a look at ON INTERRUPT. You should be able to see what is missing.
    When you say "low power", are you wanting the chip to sleep until a button is pressed?
    no need for any ON INTERRUPT here. One thing you MUST look at first is if RB_INT can wake up the PIC. Also double check your configuration fuses AND all INT related registers. INTCON and the likes.
    Yup, but the OP did ask about interrupts, so I figured he may as well start with the basics...
    I know Dave but looking at the original code
      sleep
    should have give you some pointer? OK OK OK I'm being a smart a55 as usual
    </pre>
    Jan 2006
    Istanbul
    PORTB change interrupt interrupts twice when :
    first > the pin goes low
    Second > the pin goes high.
    Thus, pin toggle happens twice and ends up at the same state.
    You should use a flag, or bounce until the second interrupt occurs.
    ____________
    Post
    This interrupt can wake the device from the Sleep
    mode, or any of the Idle modes. The user, in the
    Interrupt Service Routine, can clear the interrupt in the
    following manner:
    a) Any read or write of PORTB to clear the mismatch
    condition (except when PORTB is the
    source or destination of a
    MOVFF instruction).
    b) Clear the flag bit, RBIF.
    A mismatch condition will continue to set the RBIF flag bit.
    Reading or writing PORTB will end the mismatch
    condition and allow the RBIF bit to be cleared. The latch
    holding the last read value is not affected by a MCLR nor
    Brown-out Reset. After either one of these Resets, the
    RBIF flag will continue to be set if a mismatch is present
    a great classical ...
    I didn't see anything about the WDT nor ... but config is not shown ...
