Interrupt on RB port change with PIC18F23K20
Results 1 to 7 of 7
    Aug 2005
    Default Interrupt on RB port change with PIC18F23K20
    Hello all, I'm trying to make a low power app that use interrupts on RB4-5-6-7 port change.
    The problem is that it's always awake so LD1 blink continuously. Portb internal pull-up are enabled so I want interrupt when RB4-5-6-7 goes low.
    This is my test code:
    OSCCON = %01001110  '1MHz int osc
    ANSEL = 0
    ANSELH = 0
    ADCON0.0 = 0
    CCP1CON = 0
    CCP2CON = 0
    REGISTER
    CM1CON0.7 = 0
    CM2CON0.7 = 0
    CVRCON.7 = 0
    CVRCON2.7 = 0
    HLVDCON.4 = 0
    INTCON.3 = 1
    INTCON.4 = 0
    INTCON2.7 = 0
    SSPCON1 = 0
    TRISB=%11111111
    IOCB.7=1
    IOCB.6=1
    IOCB.5=1
    IOCB.4=1
    SW1 VAR PORTB.4
    SW2 VAR PORTB.5
    SW3 VAR PORTB.6
    SW4 VAR PORTB.7
    LD1 VAR PORTA.0
    HIGH LD1
    INTCON.0=0
    ciclo:
    TOGGLE LD1
    IF (SW1 == 0) THEN
      HIGH LD2
      sleep
    INTCON.0=0
    LOW LD2
    goto ciclo
    can someone help me to understand where is the problem (probably I miss something) and how to make it works?
    very thanks!
    You are close, you have many of the elements required.
    Go to your manual and take a look at ON INTERRUPT. You should be able to see what is missing.
    When you say "low power", are you wanting the chip to sleep until a button is pressed?
    no need for any ON INTERRUPT here. One thing you MUST look at first is if RB_INT can wake up the PIC. Also double check your configuration fuses AND all INT related registers. INTCON and the likes.
    Yup, but the OP did ask about interrupts, so I figured he may as well start with the basics...
    I know Dave but looking at the original code
      sleep
    should have give you some pointer? OK OK OK I'm being a smart a55 as usual
    </pre>
    Jan 2006
    Istanbul
    PORTB change interrupt interrupts twice when :
    first > the pin goes low
    Second > the pin goes high.
    Thus, pin toggle happens twice and ends up at the same state.
    You should use a flag, or bounce until the second interrupt occurs.
    ____________
