Hi Steve.
my pic is 18f26j11, but the internal rtcc is not a solution because i need prevent power fail, so i'm choosing the mcp79410 because it have the backup battery.
the schematic is in datasheet of microchip pag 1 in http://ww1.microchip.com/downloads/e...tes/01355A.pdf
SCL and SDA from I2C are connected to pins 14 and 15 from my micro.
After several attempts, finally managed to get the clock working, through the instructions and I2Cwrite I2CREAD. Initially I was not able to because I forgot to set the correct port.
my code:
Define LCD_DREG PORTB     ' Port for LCD Data
Define LCD_DBIT 0	      ' Use lower 4 bits of Port
Define LCD_RSREG PORTA	  ' Port for RegisterSelect (RS) bit
Define LCD_RSBIT 1	      ' Port Pin for RS bit
Define LCD_EREG PORTA	  ' Port for Enable (E) bit
Define LCD_EBIT 2	      ' Port Pin for E bit
Define LCB_BITS 4	      ' Using 4-bit bus
Define LCD_LINES 2	      ' Using 2 line Display
Define LCD_COMMANDUS 2000 'Command Delay (uS)
Define LCD_DATAUS 50	  ' Data Delay (uS)
LCDOUT $FE,1              ' start LCD
OSCCON = %01100000     ' UTILIZAR OSCILADOR INTERNO DE 4MHz
T1CON  = %10001001     ' CRISTAL EXTERNO, 1:1 PRESCALE, NO SYNCH, 8-BIT, TIMER1 ON
INTCON2.7 = 1          ' DISABLE PULL UP'S NAS PORTB'S
CM1CON = 0             ' DISABLE COMPARADORES
CM2CON = 0
ANCON0 = %11111111     ' SELECT ANALOG AND DIGITAL PINS IN PORTA
ANCON1 = %10011111
ADCON1 = %10000000
TRISA = %00000000
TRISB = %00000000
TRISC = %00111000
SCLpin   var PORTC.3
SDApin   var PORTC.4
MFOpin   var PORTC.5
RTCSec   var byte
RTCMin   var byte
RTCHour  var byte
RTCWDay  var byte
RTCDay   var byte
RTCMonth var byte
RTCYear  var byte
RTCCtrl  var byte
MEMSec   VAR BYTE
MEMMin   VAR BYTE
MEMHour  VAR BYTE
MEMWDay  VAR BYTE
MEMDay   VAR BYTE
MEMMonth VAR BYTE
MEMYear  VAR BYTE
MEMCtrl  VAR BYTE
seculo   var byte
anos     var byte
mes      var byte
dias     var byte
hora     var byte
minu     var byte
segu     var byte
'habilitar o i2c
SSPSTAT = %00000000
SSPCON1 = %00101000 'MASTER MODE SSPM E ENABLE SSPEN
SSPCON2 = %00011111 'SEN,RSEN,PEN,RCEN,ACKEN
'_______________________________________________________________________________
 'MCP7941 CONFIGURACTION REGISTERS RTCC
RTCSEC   = %10000000 'BIT 0-3 SECONDS; BIT4-6 10SECONDS; BIT 7 OSCILLATOR START                       '00-59
RTCMIN   = %00100011 'BIT 0-3 MINUTES; BIT4-6 10MINUTES; BIT 7 NOT USED                               '00-59
RTCHOUR  = %00010001 'BIT 0-3 HOUR; BIT 4 10HOURS; BIT 5 10HOUR AM/PM; BIT 6 12/24; BIT 7 NOT USED    '1-12AM/PM OU 00-23
RTCWDAY  = %00001010 'BIT 0-2 WEEKDAY; BIT 3 VBATEN; BIT 4 VBAT; BIT 5 OSCON; BIT 6-7 NOT USED        '1-7
RTCDAY   = %00100001 'BIT 0-3 DAY; BIT 4-5 10DAY; BIT 6-7 NOT USED                                    '0-31
RTCMONTH = %00000110 'BIT 0-3 MONTH; BIT 4 10MONTH; BIT 5 LEAP YEAR; BIT 6-7 NOT USED                 '01-12
RTCYEAR  = %00010001 'BIT 0-3 YEAR; BIT 4-7 10YEAR                                                    '00-99
RTCCtrl  = %01000011
'seculo = 20
gosub clock_start
PAUSE 100
start:
        I2CREAD SDApin,SCLpin,%11011111,$00,[MEMSec,MEMMin,MEMHour,MEMWDay,MEMDay,MEMMonth,MEMYear,memctrl]
        PAUSE 100
        gosub diasemana
        gosub meses
        LCDOut $FE,$80,#(MEMHOUR>>4) & %00000011,#MEMHOUR & $0F,":"
        LCDOut $FE,$83,#(MEMMin>>4) & %00000111,#MEMMin & $0F,":"
        LCDOut $FE,$86,#(MEMSEC>>4) & %00000111,#MEMSEC & $0F
        'LCDOut $FE,$C0,# MEMWDAY & %00000111
        LCDOut $FE,$C3,", ",#(MEMDAY>>4) & %00000011,#MEMDAY & $0F
        'LCDOut $FE,$C7,#(MEMMONTH>>4) & %00000001,#MEMMONTH & $0F
        LCDOut $FE,$CC,#seculo,#(MEMYEAR>>4) & %00001111,#MEMYEAR & $0F
goto start
'                         FUNCOES FUNCOES FUNCOES
clock_start:
            I2CWrite SDApin,SCLpin,%11011110,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,rtcctrl]
diasemana:
          select case  MEMWDAY & %00000111
          case 1
          lcdout $FE,$C0,"Mon"
          case 2
          lcdout $FE,$C0,"Tue"
          case 3
          lcdout $FE,$C0,"Wed"
          case 4
          lcdout $FE,$C0,"Thu"
          case 5
          lcdout $FE,$C0,"Fri"
          case 6
          lcdout $FE,$C0,"Sat"
          case 7
          lcdout $FE,$C0,"Sun"
          end select
meses:
          select case  ((MEMMONTH>>4) & %00000001)*10 + MEMMONTH & $0F
          case 1
          lcdout $FE,$C8,"Jan"
          case 2
          lcdout $FE,$C8,"Feb"
          case 3
          lcdout $FE,$C8,"Mar"
          case 4
          lcdout $FE,$C8,"Apr"
          case 5
          lcdout $FE,$C8,"May"
          case 6
          lcdout $FE,$C8,"Jun"
          case 7
          lcdout $FE,$C8,"Jul"
          case 8
          lcdout $FE,$C8,"Aug"
          case 9
          lcdout $FE,$C8,"Sep"
          case 10
          lcdout $FE,$C8,"Oct"
          case 11
          lcdout $FE,$C8,"Nov"
          case 12
          lcdout $FE,$C8,"Dec"
          end select
calculo:
        hora = ((MEMHOUR>>4) & %00000011) *10 + MEMHOUR & $0F
        minu = ((MEMMin>>4) & %00000111) *10 + MEMMin & $0F
        segu = ((MEMSEC>>4) & %00000111) *10 + MEMSEC & $0F
        dias = ((MEMDAY>>4) & %00000011) *10 + MEMDAY & $0F
        mes  = ((MEMMONTH>>4) & %00000001) *10 + MEMMONTH & $0F
        anos = ((MEMYEAR>>4) & %00001111) *10 + MEMYEAR & $0F
        lcdout $FE,$d0,#segu
Any tip to improve the code? thanks
regards
