Mcp79410 rtcc
Results 1 to 5 of 5
Thread: Mcp79410 rtcc
    Default Mcp79410 rtcc
    Hi!
    I'm new to that RTC.
    Are there any pitfalls with it?
    Does I2CREAD and I2CWRITE work as one would expect?
    Any othere problems?
    About the printed board, any concern about it. If you can squeeze all components needed by it clearly within one square inch and ground is practically all around it, it should work. Doesn't it?
    PS Does anybody now when PBP 2.60B will come out, it should not take so long any more, or...
    Jun 2011
    Portugal
    Default Re: Mcp79410 rtcc
    Hello keymuu.
    I'm building a clock based on mcp79410 and would like to ask you if you had problems with I2CREAD and I2Cwrite?
    I'm trying with these functions but without success!
    regards
    Please, allow us to help you better by providing all the details: PIC, schematic, a snip of your actual code, configuration fuses etc etc etc.
    Jun 2011
    Portugal
    Hi Steve.
    my pic is 18f26j11, but the internal rtcc is not a solution because i need prevent power fail, so i'm choosing the mcp79410 because it have the backup battery.
    the schematic is in datasheet of microchip pag 1 in http://ww1.microchip.com/downloads/e...tes/01355A.pdf
    SCL and SDA from I2C are connected to pins 14 and 15 from my micro.
    After several attempts, finally managed to get the clock working, through the instructions and I2Cwrite I2CREAD. Initially I was not able to because I forgot to set the correct port.
    my code:
    Define LCD_DREG PORTB     ' Port for LCD Data
    Define LCD_DBIT 0	      ' Use lower 4 bits of Port
    Define LCD_RSREG PORTA	  ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 1	      ' Port Pin for RS bit
    Define LCD_EREG PORTA	  ' Port for Enable (E) bit
    Define LCD_EBIT 2	      ' Port Pin for E bit
    Define LCB_BITS 4	      ' Using 4-bit bus
    Define LCD_LINES 2	      ' Using 2 line Display
    Define LCD_COMMANDUS 2000 'Command Delay (uS)
    Define LCD_DATAUS 50	  ' Data Delay (uS)
    LCDOUT $FE,1              ' start LCD
    OSCCON = %01100000     ' UTILIZAR OSCILADOR INTERNO DE 4MHz
    T1CON  = %10001001     ' CRISTAL EXTERNO, 1:1 PRESCALE, NO SYNCH, 8-BIT, TIMER1 ON
    INTCON2.7 = 1          ' DISABLE PULL UP'S NAS PORTB'S
    CM1CON = 0             ' DISABLE COMPARADORES
    CM2CON = 0
    ANCON0 = %11111111     ' SELECT ANALOG AND DIGITAL PINS IN PORTA
    ANCON1 = %10011111
    ADCON1 = %10000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00111000
    SCLpin   var PORTC.3
    SDApin   var PORTC.4
    MFOpin   var PORTC.5
    RTCSec   var byte
    RTCMin   var byte
    RTCHour  var byte
    RTCWDay  var byte
    RTCDay   var byte
    RTCMonth var byte
    RTCYear  var byte
    RTCCtrl  var byte
    MEMSec   VAR BYTE
    MEMMin   VAR BYTE
    MEMHour  VAR BYTE
    MEMWDay  VAR BYTE
    MEMDay   VAR BYTE
    MEMMonth VAR BYTE
    MEMYear  VAR BYTE
    MEMCtrl  VAR BYTE
    seculo   var byte
    anos     var byte
    mes      var byte
    dias     var byte
    hora     var byte
    minu     var byte
    segu     var byte
    'habilitar o i2c
    SSPSTAT = %00000000
    SSPCON1 = %00101000 'MASTER MODE SSPM E ENABLE SSPEN
    SSPCON2 = %00011111 'SEN,RSEN,PEN,RCEN,ACKEN
    '_______________________________________________________________________________
     'MCP7941 CONFIGURACTION REGISTERS RTCC
    RTCSEC   = %10000000 'BIT 0-3 SECONDS; BIT4-6 10SECONDS; BIT 7 OSCILLATOR START                       '00-59
    RTCMIN   = %00100011 'BIT 0-3 MINUTES; BIT4-6 10MINUTES; BIT 7 NOT USED                               '00-59
    RTCHOUR  = %00010001 'BIT 0-3 HOUR; BIT 4 10HOURS; BIT 5 10HOUR AM/PM; BIT 6 12/24; BIT 7 NOT USED    '1-12AM/PM OU 00-23
    RTCWDAY  = %00001010 'BIT 0-2 WEEKDAY; BIT 3 VBATEN; BIT 4 VBAT; BIT 5 OSCON; BIT 6-7 NOT USED        '1-7
    RTCDAY   = %00100001 'BIT 0-3 DAY; BIT 4-5 10DAY; BIT 6-7 NOT USED                                    '0-31
    RTCMONTH = %00000110 'BIT 0-3 MONTH; BIT 4 10MONTH; BIT 5 LEAP YEAR; BIT 6-7 NOT USED                 '01-12
    RTCYEAR  = %00010001 'BIT 0-3 YEAR; BIT 4-7 10YEAR                                                    '00-99
    RTCCtrl  = %01000011
    'seculo = 20
    gosub clock_start
    PAUSE 100
    start:
            I2CREAD SDApin,SCLpin,%11011111,$00,[MEMSec,MEMMin,MEMHour,MEMWDay,MEMDay,MEMMonth,MEMYear,memctrl]
            PAUSE 100
            gosub diasemana
            gosub meses
            LCDOut $FE,$80,#(MEMHOUR>>4) & %00000011,#MEMHOUR & $0F,":"
            LCDOut $FE,$83,#(MEMMin>>4) & %00000111,#MEMMin & $0F,":"
            LCDOut $FE,$86,#(MEMSEC>>4) & %00000111,#MEMSEC & $0F
            'LCDOut $FE,$C0,# MEMWDAY & %00000111
            LCDOut $FE,$C3,", ",#(MEMDAY>>4) & %00000011,#MEMDAY & $0F
            'LCDOut $FE,$C7,#(MEMMONTH>>4) & %00000001,#MEMMONTH & $0F
            LCDOut $FE,$CC,#seculo,#(MEMYEAR>>4) & %00001111,#MEMYEAR & $0F
    goto start
    '                         FUNCOES FUNCOES FUNCOES
    clock_start:
                I2CWrite SDApin,SCLpin,%11011110,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,rtcctrl]
    diasemana:
              select case  MEMWDAY & %00000111
              case 1
              lcdout $FE,$C0,"Mon"
              case 2
              lcdout $FE,$C0,"Tue"
              case 3
              lcdout $FE,$C0,"Wed"
              case 4
              lcdout $FE,$C0,"Thu"
              case 5
              lcdout $FE,$C0,"Fri"
              case 6
              lcdout $FE,$C0,"Sat"
              case 7
              lcdout $FE,$C0,"Sun"
              end select
    meses:
              select case  ((MEMMONTH>>4) & %00000001)*10 + MEMMONTH & $0F
              case 1
              lcdout $FE,$C8,"Jan"
              case 2
              lcdout $FE,$C8,"Feb"
              case 3
              lcdout $FE,$C8,"Mar"
              case 4
              lcdout $FE,$C8,"Apr"
              case 5
              lcdout $FE,$C8,"May"
              case 6
              lcdout $FE,$C8,"Jun"
              case 7
              lcdout $FE,$C8,"Jul"
              case 8
              lcdout $FE,$C8,"Aug"
              case 9
              lcdout $FE,$C8,"Sep"
              case 10
              lcdout $FE,$C8,"Oct"
              case 11
              lcdout $FE,$C8,"Nov"
              case 12
              lcdout $FE,$C8,"Dec"
              end select
    calculo:
            hora = ((MEMHOUR>>4) & %00000011) *10 + MEMHOUR & $0F
            minu = ((MEMMin>>4) & %00000111) *10 + MEMMin & $0F
            segu = ((MEMSEC>>4) & %00000111) *10 + MEMSEC & $0F
            dias = ((MEMDAY>>4) & %00000011) *10 + MEMDAY & $0F
            mes  = ((MEMMONTH>>4) & %00000001) *10 + MEMMONTH & $0F
            anos = ((MEMYEAR>>4) & %00001111) *10 + MEMYEAR & $0F
            lcdout $FE,$d0,#segu
    Any tip to improve the code? thanks
    regards
    Jul 2011
    Smile Re: Mcp79410 rtcc
    Lines 57-59 error. Did you end up remarking them out?
    SSPSTAT = %00000000
    I'm glad you got this RTC to work. I'm going to use it in an upcoming project.
    Len
