Stable ADC readings
Results 1 to 40 of 91
    Mar 2009
    Default Re: Stable ADC readings
    Yes I have (& very good it is too) , but I'd rather have this jittery AtoD values 'cleaned up' at the source (rather than putting averaging in place to address unstability caused by avoidable factors)
    Just include an RC filter on the A/D input, and put the PIC to sleep just before enabling the A/D conversion. This returns very stable readings in most applications with a stable power supply or Vref.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2008
    Ploiesti, ROMANIA
    Nice subject !
    I use a similar code for reading the over-current of one DC motor :
    check:
     vt  =0
     vs  =0
     grup=0
     cnt =0
     pause 50
     for cnt = 1 to 10
     	adcin 3, adval
     	vt=adval * 5000
     	vt=div32 1023
     	grup=vt+grup
     	pause 5
     next cnt
     vs=grup / 10
          if (vs > checkin) or (T1Count > 50) then
      	     	gpio.0=0
               	gpio.5=0
    If the averge of 10 readings it's bigger than checkin value (or time exceed 5 seconds) then gpio.0 and gpio.5 goes low.
    It's one good ideea to use ADCON instead ADCIN ? How to do this and keeping average of 10 readings ?
    Dec 2008
    Ploiesti, ROMANIA
    Default Need advice, please !
    It's this correct ?
    In header of code I add :
        ADCON0 = %10001101      ' ADC input on GPIO.4/AN3/pin3 (page 41)
                                ' MSB 1 = Right Justify                   "1"
                                '     0 = Vdd as voltage reference        "0"
                                '     0 = n/a                             "00"
                                '     0 = n/a
                                '     1 = select channel 03 (bit 2 of 2)  "11"
                                '     1 = select channel 03 (bit 1 of 2)
                                '     0 = conversion status (see routine) "0"
                                ' LSB 1 = A/D converter module is on      "1"
    And I modify the "check" subroutine like that :
    check:
     vt  =0
     vs  =0
     grup=0
     cnt =0
     pause 50
     for cnt = 1 to 10
          ADCON0.1 = 1
          NOT_DONE:
    		if ADCON0.1 = 1 THEN NOT_DONE
                Pause 10
                adval.highbyte = ADRESH
                adval.lowbyte = ADRESL
     PAUSE 10
     	vt=adval * 5000
     	vt=div32 1023
     	grup=vt+grup
     PAUSE 10
     next cnt
     vs=grup / 10
      	     	gpio.0=0
               	gpio.5=0
    The hardware it's in picture.
    Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    I've tested the code ; it's OK.
    Mar 2009
    I've used ADCIN pretty much from day one, but I noticed I was getting some *very* jittery readings (255,243,246,255,243,246 etc)...I couldn't get to the bottom of it (spent a good while trying the usual stuff), I'd forgot about this thread but thankfully foiund it with Google)
    It's the first time I've used the manual ADC method......but I'm pleased to also report my ADC readings are now solid as a rock.
    Just for the record, here's what I used on my 12lf1822 (I'm only using 8 dits ADC)...
    ADCON0 = %00000100     ' select ch1 (AN1 Pin 6)
    ADCON1 = %00000000     'set ADC +ve reference to VCC
    gosub Do_ADC
    hserout [DEC ADC_RESULT,13,10]
    'ADC sub routine...
    Do_ADC:
    PAUSEUS 50              ' Wait for A/D channel acquisition time
    ADCON0.1 = 1           ' Start conversion
    WHILE ADCON0.1       ' Wait for it to complete
    WEND
    ADC_Result = ADRESH
    Many thanks to you all on this thread...I shall never go back to the ADCIN method!
    Mar 2009
    I wish the edit feature was open longer - I forgot to turn the ADC on above, sohere's the correction....
    ADCON0 = %00000101     ' select chan1 (AN1 Pin 6), turn ADC On Bit 0
