Stable ADC readings
Results 1 to 40 of 91
    For what it is worth I agree with Steve.
    I tried ADCIN a couple of times and did not like it. Others swear by it though. ..
    Keep doing it the way you are.
    I would love to see the whole code with ADCIN. Sometime if you play with some ADC registers, and you place them Before or After the DEFINEs, it may end-up with unexpected results.
    Found in the Datasheet ...
    Note:
    The GO/DONE bit should not be set in the
    same instruction that turns on the ADC.
    Refer to
    Section 8.2.5 “A/D Conversion
    Procedure”
    a beginning of an explanation ???
    ADCIN doesn't work with port pin aliases. Use ADCIN 2,W0, or define PinProbe as a constant. PinProbe CON 2 would work.
    Also ADCIN doesn't setup TRIS, ANSEL or ADCON1. So you end up with Fosc/2 for your A/D clock because ADCON1 defaults to all 0's. So you're way out of spec for a 4MHz osc. Fosc/8 would be a good one to use with 4MHz (see datasheet).
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce ... 1K points ...
    as always !!!...
    Shame on me.
    Blonde moment here too
    Disclaimer: "Blonde moment" is a deliberate sentence that belongs to Mister_e user and plah plah plah, shall not be considered as offensive plah plah plah. Complaints about that shall not be send to Admin, Mods, user but only to Mister_e user plah plah plah....
    Hi, Steve
    I Think the "Blonde" term use rights already belong to KarenHornby ...
    so, you'll have to buy a licence ...
